Prior to my ownership, someone cut openings in the basement ductwork, presumably to heat and cool the basement. Unfortunately, it dumps so much cold air down there (even with the vents closed) that the second floor doesn’t get adequately cooled. I have no tinterest in heating or cooling the basement, so I want to remove the vents and block the openings in the main supply and return. Is there a more appropriate way than just fastening a piece of sheet metal over the hole?
Sure, fasten a piece of metal, and seal it with duct sealer. If you haven't already, insulate the ducts.
Ductwork is low-tech stuff, common sense goes a long way. If you think you need to balance the system install shutoffs in the ducts coming off of the supply.
Prior to my ownership, someone cut openings in the basement ductwork, presumably to heat and cool the basement. Unfortunately, it dumps so much cold air down there (even with the vents closed) that the second floor doesn't get adequately cooled. I have no tinterest in heating or cooling the basement, so I want to remove the vents and block the openings in the main supply and return. Is there a more appropriate way than just fastening a piece of sheet metal over the hole?
