In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Isolating rim joist from poured concrete
oldlou | Posted in Construction Techniques on August 29, 2002 09:43am
I am adding an addition, built on a slab, to the side of a house built with a crawl space. The owner wants a level floor between the two spaces so the slab will be poured up to the top of the rim joists. I do not want the concrete to contact the rim because I fear that the rim will be rotted out by the lime in the concrete.
Is my fear unwarranted? What can I use isolate the two? My concrete man first wanted to use aluminum, but I nixed that, now he wants to use black board expansion joint material. Is this a good choice?
I wanted to use copper but the crete man thinks that too spendy for his fixed price. I concur, and am willing to make a satisfactory compromise.
  1. Brudoggie | Aug 30, 2002 04:07am | #1
    Try Ice Shield on the rim, should provide the protection you are looking for, at a relatively low cost. How are you planning on controling movement between the two different foundations?
     Brudoggie
    1. oldlou | Aug 30, 2002 04:38am | #2
      Could not come up with a foolproof method that would not possibly adversely affect the main house, a very expensive log house. The point of connection is a 57" wide hallway between the two buildings. At the start of this hallway the flooring will change from hickory hardwood, the real deal, to carpeting. We are hoping that this transition line will disguise any small differential movement.
      What do you think of our plan? Do I have my head in the sand AGAIN. argh.
      1. ANDYSZ2 | Aug 30, 2002 03:14pm | #3
        I used concrete board nailed to the rim joist then poured the concrete up to it.
        ANDYSZ2
A Better Way to Budget in Residential Construction
Using transparent budget reports throughout the building process can help keep everyone's expectations on track.
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
  • Linda Reeder: Architect, Professor, and Author
  • Podcast 458: PRO TALK With Glue Expert Bob Behnke
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • Tool Guide 2022
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
