Joist Hangers – Hanger Nails 10/16
bluegoat | Posted in General Discussion on June 1, 2009 01:30am
I have 2×8 joists for an inside ceiling – attic above. I am using simpson joist hangers. The 2×6 joist hangers seem to say usable for either 2×6 or 2×8. The 2×8 joist hangers say 2×8 or 2×10. Should I just go with the 2×6 joist hanger?
The simpson joist hangers have double shear strength which allows nails to cross in the middle – when is this feature desired or needed?
The hanger nails at my lumber yard say 10 on the head for the standard nails and 16 on the head for the sheer nails. The box that has the 10 nails seems to have two similar nails, one marked with 10 on the head and another non-marked. I asked the yard about this and they said they all come from the same box but inspecting the nails shows the 10 nails to be a 1/8 longer, should I go to the trouble to sort through and use only the nails marked 10? The box of galvanized hanger nails all seem to be marked with a 10 on the head.
  1. LIVEONSAWDUST | Jun 01, 2009 01:44am | #1
    For that application,which is a fairly light load, I wouldn't bother sorting them out,
    either nail should be fine. The 2x6 hangers should be fine also.
    1. bluegoat | Jun 01, 2009 06:38pm | #2
      So this implies that if the load were going to be heavy you would sort them out?My joists are already in and I did sort through the nails I am just wondering if others would have. I should have just grabbed the galvanized not that much more expensive and no need to sort.This likely won't be the last time I am rolling joists so I am hoping for some general best practices. Any idea on the double shear strength?
      1. frammer52 | Jun 01, 2009 07:01pm | #3
        My experience with hanger nails is slim, we used gav. 12d's, but, if I was faced with a choice, I would use the marked ones.
      2. LIVEONSAWDUST | Jun 01, 2009 10:16pm | #6
        No, then I would have asked the yard to sort them out in order to give me whatever size it was i needed.   All I meant was why worry about it in your situation
  2. Piffin | Jun 01, 2009 07:30pm | #4
    use the marked ones if getting inspected.
    The cross in middle is Simpsons newer LUS hanger style. uses fewer nailes and is easier nailing, and wood does not get 'nail poor' from so many tecos and 16 toenails all gathered round.
    The 2x6 size is fine
  3. Frankie | Jun 01, 2009 10:04pm | #5
    When you look at the Simpson Catalog for joist hangers, they list the hanger for each situation in order of cheapest/ easiest to install to heavier duty/ most expensive. In your case, use the first hanger listed for your size joist - the cheapest. In the Fastener columns, it tells you what the min and max nail schedule you can use - header and joist. It is important that you follow those.
    Frankie
    Flay your Suffolk bought-this-morning sole with organic hand-cracked pepper and blasted salt.
    Thrill each side for four minutes at torchmark haut. Interrogate a lemon.
    Embarrass any tough roots from the samphire. Then bamboozle till it's al dente with that certain je ne sais quoi.
    Arabella Weir as Minty Marchmont - Posh Nosh
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
