FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Laminate flooring
gamnjb | Posted in General Discussion on November 5, 2002 12:38pm
I want to put in some of the new laminate flooring material in my kitchen.  The type I am looking at is a “snap” together and doesn’t require glue.  The instructions indicate that 100% silicone caulk should be used around the perimeter to keep water from getting under the floor.  My concern is, should I actually glue the pieces together to prevent any spills seeping through the cracks of the floor.  Any recommendations?  Any help is appreciated.  Thanks.  Mac
  1. dutchblue | Nov 05, 2002 12:59am | #1
    Depending on the type, pergo etc.. the perimeter sealant is all you need, and around fixtures that have a tendency to leak (toilets, exterior doorways, sliding glass doors).  Some systems recommend gluing the upper part of the tounge in high moisture content areas.  Most snap together systems have a 30 min time frame before standing water will absorb through a seam.
    Good Luck,
    Matt
    The enemy of the best, is the good enough.
    1. gamnjb | Nov 06, 2002 07:59pm | #2
      Thanks for your information.
Make Mudsills Square and Level
Careful measuring, precise layout adjustments, and repeated double-checks pay off with a faster, frustration-free build.
  • Convert a Porch to a Mudroom
  • Podcast 599: Trees Moving Buildings, Epic Thermal Bypasses, and Supplemental Dehumidification
  • Podcast 599: Members-only Aftershow — Tools That Changed Residential Construction
  • Remodeling Done Right
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Shop the Store
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
