In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Laminate Repair
| Posted in General Discussion on November 17, 2002 09:27am
I was installing an oak edge to the side of a cutting board well, when the last brad, (of course!) curled upward and poped out a pencil eraser sized chunck of laminate. I found the piece in my beard, carefully cut away the underlayment on the bottom side, set a very thin dab of glue in the hole, and set the piece back in place.  It’s almost perfect and if your standing up you can’t see it at all, but if you lean down and look hard you can see a fine line around the chip.
 Can you guys think of anything I can work down into that line to erase it? the counter top is white, I tried to work some caulk into the line, but I need something that will dry hard. I think if I can get something in there and then plane over it with a razor blade, I can make this problem disappear.  White-out? Apliance touch up?
 The home owners have seen it (where?, right there!, Where? there!, ) and are fine with the repair as is, but I would like it to be right. if I can’t fix it I’m going to route out the cutting board well and make a bigger cutting board.
Justus Koshiol
Running Pug Construction
    jocobe | Nov 17, 2002 04:26pm | #1
    Kampel SeamFil   http://www.kampelent.com/seamfil.htm
    jocobe
    1. KenHill3 | Nov 17, 2002 08:52pm | #2
      Ditto on the seamfill- dries hard. Don't use it much myself since all my plam seams are perfect (!) LOL.
      Ken Hill
        BarryE | Nov 17, 2002 09:15pm | #3
        I find as a rule, that if I'm not happy with it the way it's repaired now, I'm not going to be any happier by squeezing a bunch of cr*p into the joints. It will only make it more noticeable.
        If it's going to keep you awake, you might as well fix it like you want to
        Barry
        Warning: dates in the calendar are closer than you think.
        Barry E
        1. Justus | Nov 17, 2002 11:49pm | #4
          Jocobe you are the man! I'll try it.  Barry, your are right, but this is a very small blemish, and if this stuff doen't work, I will rout out the whole thing. Justus Koshiol
A Better Way to Budget in Residential Construction
Using transparent budget reports throughout the building process can help keep everyone's expectations on track.
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
  • Linda Reeder: Architect, Professor, and Author
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
