Has anyone used Colorfast 2-part epoxy laminate seam fillers before?
Any tips or hazards.
http://www.colorfastind.com/interiorframes.htm
Preferences to Colorfast, Kampel or others.
I was going to use Kampel’s but couldn’t find the the color mixing
ratios for the Formica portico marble laminate I’m using.
FYIs.
Had to return one sheet of the portico marble because the colors varied too much between sheets
Colorfast also make caulks to match laminates from differnt mfgrs.
Thanks,
Mike
I was going to use Kampel's but couldn't find the the color mixing
ratios for the Formica portico marble laminate I'm using.
FYIs.
Thanks,
Mike
