FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Landscape Sound Reduction
hmj | Posted in General Discussion on May 8, 2008 02:57am
We are looking at some property in the Live Free or Die State. One of the big drawbacks is the proximity to the state highway. I thought of pine trees (white pine) and a tall stockade type fence, far enough from the road so the snowplows don’t get it. Potential problem with the trees and road salt. Bounce me some ideas on what could be used a sound reducer please.
    nater | May 08, 2008 03:20pm | #1
    While the trees may help a little bit, you need something solid to really cut down on the noise by reflecting the sound waves. On This Old House when they did their 25th year, they had the same problem. They had some specialist come out, and said the best way was a solid fence (they used stone) about 3 feet high. Most of the noise came from the tires hitting the road, so a higher fence doesn't get as much improvement per dollar spent.
    Then the trees behind the fence to help cut down on a little more noise & sight of the highway.
  2. TBone | May 08, 2008 03:23pm | #2
    How much room do you have? How about a berm with taller shrubs instead of trees and a groundcover to hold the soil? More mass than a fence would have. Salt might still do a number on them though.
    Jeff_Clarke | May 08, 2008 04:39pm | #3
    Solid masonry wall 6' high.   Very little else will make any difference.
  4. VaTom | May 08, 2008 04:59pm | #4
    If you go underground you won't hear a thing.  Malcolm Wells promoted that issue for decades.
    PAHS works. Bury it.
  5. john7g | May 08, 2008 05:24pm | #5
    berm, solid fence, & 2-3 rows of leyland cypress
  6. DanH | May 08, 2008 05:55pm | #6
    The berm is a good idea -- the closer to the road it is the lower it can be and still be effective, but anything over 2-3 feet will help a lot, regardless of how close. Beyond that, any sort of shrubbery will absorb sound, and your local nursery should be able to point you to salt-tolerant varieties. There are also salt-tolerant pine varieties.
    Keep in mind that most highway noise is tire noise, fairly readily handled by low (less than 6 feet) absorptive barriers. However, especially if you're on a hill or near an intersection (where trucks will accelerate/decelarate) there is also the noise from large truck exhausts -- much harder to deal with since it's low-pitched and emitted from about 10 feet off the ground.
    In any event, unless this is an especially busy and noisy highway you'll find that you stop hearing the noise after a few weeks. Humans have a remarkable ability to "tune out" noise. (If this weren't the case the divorce rate would be twice what it currently is.)
    What is wanted is not the will to believe, but the will to find out, which is the exact opposite. --Bertrand Russell
  7. BigBill | May 08, 2008 06:09pm | #7
    If you are going to build on this property use a sprayed foam insulation and triple pane windows and you will have a quite a quiet home.
    If you are looking a an existing house.  Look at http://www.retrofoam.com/ .  Dense packed cells is also a good sound deadener.
Make Mudsills Square and Level
Careful measuring, precise layout adjustments, and repeated double-checks pay off with a faster, frustration-free build.
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
  • Fine Homebuilding Issue #320 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
