It’s been quite a few years since I assembled any copper plumbing, is there anything special I need to know when using the lead-free solder vs. the old 60-40 solder?
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
1) Assuming your previous experience is with a propane torch -- get a MAPP gas torch - makes your life easier. Prpoane will work - MAPP is a little hotter and seems to be easier.
2) Make sure the flux you have is for lead-free.
Sweat away!
Jim
The new solder alloys like Silvabrite are really nice to work with, especially compared to the old 95/5 solders that were about the only lead-free choice in the days when lead was outlawed. Silvabrite has a melting range of over 100 degrees.
The old 50/50 and 60/40 lead solders were easy to work with because they have a melting range of 50 degrees or more. Within that range, they become mushy, or pasty, and can fill gaps much easier than solders like 95/5 that have a melting point rather than a melting range. 95/5 has only about a 5 degree range, which is essentially a melting point.
Essentially the same except for the flux. Make sure the flux is for lead free. This flux is white, similar to borax flux but is a different flux altogether. Melting time is very slightly longer than the leaded solder.
mike
Thanks everybody. Doesn't look like there's any special "gotcha's" with the lead-free, I'll give it a stab. I'm plumbing a new tub & shower, the plumbing will be darned difficult to get to after the remodel. I wanted to do it "right" the first time & not have to worry about it in the future.
I second the MAPP torch suggestion--but I have never heard of a special flux for lead free solder. The stuff I use is Good Crest; it's a self-cleaning soldering flux that comes as a transparent, dark amber-yellow paste.
Dinosaur
I was thinking of starting a thread asking for recommendations on soldering pastes.
Gotta be better products than the white frothy stuff.
Always had a leaning towards the greasy stuff.
be Made in Italy
I've never even seen the 'white frothy stuff'; can't quite imagine it, either. All the fluxes I've ever seen have been the greasy stuff.
I goofed on the name of the stuff I use now in my first post, it's not Gold Crest or whatever I wrote; it's CREST GOOD. Made by the Crest Good Mfg Co. of Syosset, NY. I never see it in big boxes or DIY hardware stores; I can only get it from my plumbing sub. It's a zinc chloride-based flux; self-cleaning, not water-soluable, and very, very easy to work with.
As a bonus, if you wanna clean up yer pipe work to impress the client, just smear some on a rag and wipe down the pipes with it. Shines 'em up better than Brasso....
Dinosaur
Thanks, I'll be looking into that.
What type of solder do you prefer?
Kester 96% tin / 4% silver.
Dinosaur
CrestGood¯ is one of the best fluxes I have ever used, & I think I have used almost every kind.
I've been using it exclusively for the last 15 years, and got to the point where I kinda forgot how much better it is than anything else and took it for granted. One day I ran out while on a job 40 km from here and ran to the nearest hardware store where, naturally, they didn't have Crest Good. So I bought what they had just to get through the day.
Ten minutes later I'm cursing and swearing and watching my solder bead up and fall off the goddamn pipes and spatter all over the place....
Dinosaur
Why even consider using copper in the firs place????
Because.
Dinosaur
Maybe because copper is antimicrobial http://www.copper.org/antimicrobial/properties/homepage.html and that some older homes' electrical is grounded through the copper water lines.
Or he, like me, likes the look of copper. ;)A La Carte Government funding... the real democracy.
60/40 & 50/50 can fill gaps better than the new solders.
Biggest difference is todays water soluble fluxes, they don't like to get too hot & they hate wet environments.
I don't know who said that one melts at 50 degrees & the other at 100 but I would disregard that.
The old 60/40 & 50/50 stay a solid until about 370 degrees & silverbrite 100 stays a solid until 440 degrees.
Remember to the let the pipe & fitting melt the solder not the torch.
"I don't know who said that one melts at 50 degrees & the other at 100 but I would disregard that."I think the poster was talking about the RANGE of melting temperature.
That makes sense, I had to go back & re-read his post.
