An old girl friend had passed my name on to one of her friends who was looking for builder to finish out some skylight shafts where four new skylights had recently been added during a reroofing job. When I arrived at the “scene” to begin work I had to stop in my tracks. Two of the skylight additions had been put into a low pitched scissor truss roof and ceiling system. Unfortunately four of the eight trusses had been “modified”, three trusses having the rafter and bottom cord cut and one having just the bottom cord cut. Upon informing the homeowners of the situation I was also told about leaking problems they have been having prior to the new roof and since the new metal roof installation.
I have taken care of the loading issue with the cut trusses by adding an internal ridge beam and appropriate load bearing supports but I would love to hear some feed back on proper roof installation and how to approach the homeowner and contractor regarding the leaking problem.
The roof low down… A 3.5/12 pitch transitions into a 2/12 pitch on one side of the house. Two new velux skylights with metal roof flashing kit are installed into the 3.5 pitch, and leak during heavy downpours. One old site built skylight sits on the 2/12 pitch and leaks. The transition flashing between the pitches tends to puddle water like a trough and the lower edge of the transition flashing only overlapes the lower metal roofing by 2.5 inches. The purlins are visible under the transition if I look up under there a little. The last heavy rain storm the homeowners had a couple gallons of water come into their kitchen through a hole in the sheetrock ceiling and onto their custom built fir cabinets. The leak occured directly below the old site built skylight on the 2/12 pitch. There is also water signs at the plywood seams in the garage which sits under the 2/12 pitch but further out on the outside of the kitchen wall. However that water sign is nearer to the newly installed skylight 14 feet away from the old one. The water marks are spread out over a large area under the new skylight. The contractor has been back twice and put a whitish caulking sealant around the sklights and has also installed closure foam flush with the lower edge of the transition flashing. It looks as though a clear silicon was used to seal off some of the leaking areas also.
What is proper flashing of the transition and skylights? How about overlaps and sealants per pitch? Who pays for the sheetrock fix in the kitchen and for my time in figuring out and correcting whats been going on?
wow !! steveo
Wow! is right.
I've done a couple thousand shylights of all kinds but I don't feel like I can give much advicce here without a picture or four.
Were these shylights installed withthe new steel roof or were they already in the old roof and steel aplied around them? Did the roofers cut the trusses up?
Who pays? The owners do. You stay out of assigning blame. You are there to provide a serevice in fixing it. If it gets nasty, (I would if someone screwed up my house like that) the judge will have to decide that aanswer.
"The first rule is to keep an untroubled spirit.
The second is to look things in the face and know them for what they are."
--Marcus Aurelius
