I’m converting an attached garage into living space. My intention is to use the DRI Core subfloor system which consists of 2’x2′ wood panels with a raised plastic membrane on one side.
The garage floor has a 3-4inch draft over 20feet. What is the recommended method to level this floor espcially considering having to feather it out?
If you have a step up innto the house, just pour another slab on top flush with house
The best employee you can have but you wouldn't want him as a neighbor " He the shifty type"
SLC would do the trick, too, albeit expensively.
Boris
"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
concrete and feather it out... just tell them what you are doing when you place your order... use a sand rich mix with pea gravel... it's not that big of a deal
Pony
