Looking to put shallow beams in a kitchen similar to the picture. Room is about 19 ft long x 14 ft wide, beams would go the short way. Question: how woul;d you integrate lighting into this ceiling? What would look best? Recessed cans centered between the beams? Or what style of surface mount fixtures?
“Put your creed in your deed.” Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.” T. Roosevelt
Similar to what picture?
edit: There it is.
It would help seeing the cab layout, whether there's a peninsula or island. The beams will com into play, but what you're going to light is the most important consideration Might be a good place for general lighting (cans) in a pleasing layout re. beams and then some low voltage small floods and pendants according to the cabinet layout.
http://www.quittintime.com/
Edited 3/7/2007 4:50 pm ET by calvin
Here's our kitchen tonight -
You could "faux bois" the DW beams, if you prefer
Edited 3/7/2007 6:57 pm by McDesign
