FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Looking for advice on hanging a bay w…
| Posted in General Discussion on July 26, 1999 08:31am
In the continuing sometimes fun and sometimes frustrating passtime of building my own house, I have another question.
I’m wondering how bay windows are normally supported when they are placed
in a straight wall.Do I just angle braces from the bottom of the window back to the wall, or is there some other way of doing this.
How about the roof. How are the rafters normally supported above the window. Do I just run a top plate on top of the window and set my rafters on that?
I’ve attached a very rough drawing with my proposed braces and rafters shown as dotted lines.
Looking for any suggestions or help. Thanks in advance
  1. Guest_ | Jul 26, 1999 08:31pm | #1
    I submitted a drawing to our building inspector for our bays that was almost as schematic as yours and they all but laughed. My early days. Instead, the inspectro dropped by the morning of the installation to check what the carpenters we hired intended to do.
    Our bays are fairly small -- about 5' across, 2' projection -- and are supported partly just by being nailed to the wall studs. The skirting underneath has a couple of braces as you are considering building, attached to a ledger nailed to the house and boxed in for appearances (I don't like the tapered skirt look much).
    Need more detail, like size of bay. If it is heavy and/or will have people sitting in it posts to the ground are the strongest, but wall mounting is possible if the wall is strong enough. The bay manuf. most likely has guidelines of what is sufficient. The roof you want is called a "hip roof" which is not that complicated to frame if you like geometry -- basically rafters radiate from the wall to the outside of the bay, forming three planes.
    I've read some people use cables to "hang" the bay from the header, permitting easy adjustment -- not familiar with this.
Double Dormer Transformation
This historic schoolhouse was transformed into a stunning four-bed, three-bath home with ocean views and a modern open-concept design.
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
  • Fine Homebuilding Issue #320 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
