Looking for Cremone bolts
| Posted in General Discussion on November 26, 2003 01:42am
 Those are the door hardware that slides a rod up into the top and down into the floor.   Anybody got a source for good ones?  As I understand it the Italians make the best ones but since I can’t a source for any I can’t be too choosey
  1. jimshome | Nov 26, 2003 01:58am | #1
    Here is the first one that popped up. Turns out Baldwin makes at least one version.
    http://locksmd.com/baldwin/baldwin_cremone_bolts.htm
    I can get you some more to check if you want.
    Jim
     This above all, to thine own self be true, and it must follow as the night the day, Thou cans't not then be false to any man      Hamlet
  2. alias | Nov 26, 2003 02:24am | #2
    hey frenchy- i got mine from germany i'll look at work and see if i still have the address . i was told the german have the premier specialty hardware inventory. what i do remember is the bolts were 8'6" w/ 5 slider guards . and the bolts came in 10' foot sections( shipped in a large tube) and cutting ,milling, went on at the job. for another lead i would look into zeluck windows in brooklyn ,new york. (a very fine product) they could give you a possible lead . http://www.zeluck.com....... slainte' bear
    "expectations are premeditated resentments"
    Edited 11/25/2003 8:58:53 PM ET by the bear
  3. JohnSprung | Nov 26, 2003 03:31am | #3
    I looked for new ones a while back, and discarded all the links because they were so outtasight expensive, like nearly $400 for one set.  Try wrecking companies aka architectural salvage.
    -- J.S.
    EricPaulson | Nov 26, 2003 04:03am | #4
    BAER the big supply book. If you never heard of it try a Google but last I know you can't order on line.
    Also a place called KLAFFS in Greenwich, CT. Just installed a Polished Brass Cremone on a pair of Cherry French Doors and it was a nice product and real easy to install. Maybe Klaffs has a website.
    Eric
