Hi there,
I’m reroofing our screened-in porch and its slope is about 2″-12″. It joins the main roof (which is 4″-12″ slope) of the house. the joint linking the 2 roofs leaks every rain fall, and spring. IKO makes a product that seems ideal to redo the low slope roof (Its called ROOF FAST). But it doesn’t solve the joint problem.
Would it be overkill to tuck a waterproof membrane under the 30lb tar paper at the edge of the 4-12 roof so that it straddles that joint? I guess I can only tuck it in about 5″ or 6″ ’til it reaches the point where the asphalt shingles are nailed. I would then apply the ROOF FAST. Then I would put a wide aluminum strip the length of the joint that would be tucked in under the shingles and over the ROOF FAST.
How’s that?
Thanks for any response,
Dan
It would help to know where you live.
Of course. Montreal. Cold winters. Very.
