Lvl Header for Garage Door question.
Hello.
Does a 3 1/2″ thick x 7″ deep x 10 ‘ long lvl header sound appropriate for a 9×7 garage door header that will sit under a 4/12 hip roof (single story) with no snow load?
Edited 6/20/2008 12:57 pm ET by blownonfuel
The manufacturer will be able to tell you for sure, but if it's on a gable wall I would say nail 'er up.
All I ever wanted in life was an unfair advantage...
What supports it? 8' header, 9' opening can't be good.
Everything will be okay in the end. If it's not okay, it's not the end.
Good catch
DoH!! My fault. 10' header for a 9' door.
Depends on how much weight it's carrying. You haven't really given us any info that would address that.
Stick framed roof, or trusses?
How big is the garage?
Where does the door fall in the framing layout?
Hello BossHog,
Stick Frame
Garage is 23' deep x 26 wide.
2 - 9' garage doors on each side of center.
2' between doors.
Edited 6/20/2008 12:58 pm ET by blownonfuel
Are the doors on the 23' wall or 26' wall?
The very premise of gun control is to, by law, demand that good becomes defenseless. And when good is defenseless, evil wins. I will not let that happen. [Ted Nugent]
26'
The program I have won't analyze a 7" deep member. It does show that a 9.5" deep one works. Maybe someone else has soemthing to run it with.
The law could not restore life to my dead carcass. [John Locke on the right of self defense]
Thanks BH, One of my lumber yards told me to go with two 1 3/4 thick x 9 1/2 deep lvls and put them together to make one 3 1/2 x 9 1/2, the other lumber yard suggested the 3 1/2 x 7.
It could be that some LVL manufacturers make LVLs in a 7" or 7 1/4" depth.Honestly - It sounds a bit thin to me at that depth/span. But it might be O.K with no snow load.
If people knew how hard I worked to get my mastery, it wouldn't seem so wonderful at all. [Michelangelo]
Boss, check out page 37:
You're right that it works according to their chart. But it uses L/240 & L/180 for deflection. I don't go that low.
For Clinton, the question of whether a gun is good or evil depends simply on whether a government employee's finger is on the trigger. [James Bovard]
I didn't see that. Good call.
Hey - I wasn't hired for my LOOKS, ya know.(-:
The trouble with wearing a name tag at a convention is that everybody knows exactly who you are when you fall asleep.
Thanks For all the help. I think i'll order the 9.5 deep.
Sounds good to me
The Georgia-Pacific span tables say you're good to go.
