Making a Soundproof Door
rvt | Posted in General Discussion on March 17, 2014 09:34am
I am a fairly skilled carpenter, and am just starting to build a house in southern Mexico (where I live).  I want to make the bathroom as quiet (on the outside) as possible.  The walls are going to be a panel of concrete and pulyurathane combined (5″ thick) and so I think the door is the weak spot.  I am wondering if I make a door with the two faces from thick (1/2″) plywood or MDF, brace them internally on a system of ribs that only are attached to one face interspersed with ribs on the other face (but not touching except at the rim) would give a substanially noise-reduced door.  Any ideas out there?
  1. DanH | Mar 17, 2014 09:58pm | #1
    There is some merit to what you propose (though it would be fairly heavy, with two sheets of 1/2" plywood).  What you need is a combination of stiffness, mass, damping, and isolation.
    From an acoustics standpont it would be wise to make the two faces different with weight/stiffness (eg, one 1/2" and one 3/8") so that they don't resonate at the same frequency.
    It would also be wise to somehow introduce some damping, but I haven't got a good idea for that.  Perhaps put some sort of soft rubber between the plywood and your ribs ...
    It would be nice to somehow isolate the two sides around the edge, perhaps with some sort of rubber section between.
    (And, of course, there are no doubt sound-damping doors for sale commercially.  But what fun is that?)
  2. calvin | Mar 17, 2014 10:09pm | #2
    rvt
    Split the jambs at the outer edge of the stops, sound damper in between.
    If for the CIA, 2 doors-offset and at an angle to each other.
New House, Old Shell
A full gut remodel brought new life to an 1821 home that had undergone several misguided renovations.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
