Metal studs
Joe | Posted in General Discussion on January 12, 2003 07:22am
I’m working with metal studs for the first time.  It’s my understanding that the strength of the wall unit is dependent on the wall board attached to the studs.  I want to add a layer of Celotex sound stop under the wall board on both sides.  Am I going to run into a problem with this?  This will be an office of one apartment backing up to a living room of another apartment.
  1. calvin | Jan 12, 2003 07:52pm | #1
    Joe, should be no problems with your design.  For a more stout wall, you might want to insert the "u" shaped cold rolled steel reinforcing through the holes in the studs.  If 25 ga. studs, this will further tie them all together and stiffen the wall.  If you used 25 ga. and the wall is no taller than 8', you probably don't need the reinforcing metal.  The channel is available from a commercial steel stud/drywall supplier.
    __________________________________________
    http://www.quittintime.com/
  2. Jencar | Jan 12, 2003 08:04pm | #2
    Used to work for a school disctrict, divided up a lot of larger classrooms with metal stud walls, and wanted to isolate the sound from each area.
    We put in fiberglass insulation to help deaden sound transmission, put drywall over that, sealed up the joints with a coat of mud, and glued vinyl coated Celotex tackboard over that for additional sound deadening and tackable wall surface. Might be a practical solution for the office side, saves a lot of drywall finishing labor.
    Jen 8)
    Whatever works!
      Joe | Jan 12, 2003 09:46pm | #3
      Thanks.  I like the Celotex tackboard idea for the office side.  It will be my office and I'm always sticking push pins into the wall board.
  3. Frankie | Jan 12, 2003 10:33pm | #4
    You are asking a question about wall strength but refering to sound isolation. Two independant topics.
    Strength of an interior wall should primarily come from it's framing and not its drywall. Unless you are going taller than 9' you can use 3 1/2" light guage studs.
    For sound deadening, I prefer sound attenuation batting in the form of mineral wool. It is very easy to work with.
    A second level and very effective way of isolating sound is to use a resilient channel on one or both sides. USG has a diagram on their web site http://www.usg.com.
    You can also use 3 1/2" track, top and bottom, and then use 2 1/2" studs, staggered. (Note: This requires double the number of studs.) That way, each side's sheathing is fastened to independent framing. Less sound transmission at minimal cost in materials. The additional labor involved with metals studs is also minmal because you are only fastening one side.
    Use 5/8" GWB. I think code requires the GWB to be 1 1/4" (double layer 5/8") between separate dwellings, but I could be wrong. This too, will go a long way in deadening sound.
    Of course, any combo of the above is good too.
Monitor Both Outdoor and Indoor Air Quality
The sensors and mapping tool from PurpleAir can help residents strategically use existing air filters.
  • Monitor Both Outdoor and Indoor Air Quality
  • What You Need to Know About Installing Steel Siding
  • Podcast 570: PRO TALK With Project Manager Jeremy Hess, Part 1
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
