hi does anyone know of any good sites for duct material I do alot of kitchen renovations and when the micro is ducted to the outside through the cabinet i hate the way the connections areeven if they are taped i know the voids in the duct work are collecting grease ! any suggestions ?? or should i just use my brake and make my own parts???
An FHB Podcast listener wonders if they can fix a failing foundation with PWF, the crew weighs in.
Greetings woody,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Click here for access to the Woodshed Tavern
Click here to visit the beginning of Breaktime
Let's run this thru again.
bump
woody,
Looks like yer outta luck here as far as that question goes.
Cheers
be 'I'm so sorry, Uncle Albert'
A good HVAC supplier is your friend.
Hey Woody.
I deal with the same stuff.
In fact, Tuesday I am running the duct behind wall.
I always, if possible, run behind the drywall with my duct and then when I install the microwave, open up the duct at the right spot, tape from inside around the drywall, etc and set the microwave.
I avoid running up thru the cabinet unless I have to.
With that said, I go to the local HVAC supply house and just get 3 1/4"x 10" length of pipe, drop it into place with an end cap and buy the correct fittings to get it to it's exit point.
It will have 1 more turn in it as the fan is rotated to the back and then goes up or down to it's exit (no one ever puts them on the exterior wall so I can go right out) and then to exterior.
Flow is fine and clients love not having the duct in the upper cabinet. (I always hated that)
