Moss on 3 tab shingles
redtoolbox | Posted in Construction Techniques on April 19, 2007 03:36am
What is the best way to get moss off a shingle? I found some info from “ask the builder” site, but I have gotten some extremely bogus info from there. He says oxygenated bleach and a brush.
  1. ChicagoMike | Apr 19, 2007 03:40am | #1
    I have heard of the same thing. I also have seen zinc coated metal strips applied to the roof to prevent it from coming back.
  2. junkhound | Apr 19, 2007 03:57am | #2
    I've used 3500 psi, 4 GPM pressuer washer with 25 deg nozzle with good effects on own roof.
    If the moss is thick, it will just roll off, if thin, it is much more tenacious.
    You can alway leave it on for effect <G>
    1. redtoolbox | Apr 19, 2007 04:01am | #3
      Where should I position myself to fire the hose. I am not big on heights.
      1. junkhound | Apr 19, 2007 04:09am | #4
        Only way it has worked for me is to be ABOVE where you spray, which means you need to walk the roof ridge.
        There are guys in the Seattle area make their entire living pressure washing moss.
        My roof is 30 ft up, but is only 3/12.  I use a 100 ft 3/8 hose to the PW on the ground.
        YOU NEED TO BE CAREFUL OF THE THRUST FROM A PW ON A ROOF, IF NOT USED TO THE THRUST, YOU CAN GET PUSHED OFF THE ROOF  (dont ask how I know that <G>)
        Edited 4/18/2007 9:09 pm ET by junkhound
    2. mojo | Apr 19, 2007 02:01pm | #6
      "You can alway leave it on for effect <G>"
      lol.  They are paying big money for 'green roofs' down in NYC.
      JDRHI | Apr 20, 2007 04:28pm | #8
      So thats where "the sun don't shine".
      J. D. ReynoldsHome Improvements
  3. pacificsbest | Apr 19, 2007 07:26am | #5
    Here in Seattle, as the last poster mentioned, you see every other roof covered with moss. It's mostly sections of roofs that don't get a lot of sun (that's when the sun is out this time of year!).
    If you pressure wash, be carefull with the pressure and the age of the roof. The best way to prevent moss is spreading on products such as "Moss-away" once a year. You might find it in garden sections at stores where you live.
    Be carefull up there, it's slick!
    Well, Guess I have to learn how to do THAT, now!
  4. alanj | Apr 20, 2007 05:50am | #7
    Hi, Red
    Just dealt with that problem. Our insurance co. insisted on a visual inspection on our house a while back. He flagged a roof on the north side of the house as being "at risk" because of a little moss.
    I used some lawn type moss killer that came in a gallon container with a lid designed to be attached to a hose. I poured the solution into a pump up garden sprayer, diluted it with water, (about 3 to 1, I think this was pretty strong), and soaked down the roof from a bedroom window that overlooked this shed roof. This roof is pretty small, about 10 by 12', so the little sprayer worked great and it blackened and killed the moss in just a day.
    I just looked at the container and it is "Rapid Green" brand moss killer but I imagine there are many others.
    I used the little sprayer to avoid ladder work and overspray. The instructions say to avoid cement products and we have an interlocking brick patio below.
    Edit to add: I think a pressure washer would take a few years of life from most roofs. Certainly so if asphalt or wood. Should be okay if you're lucky enough to have slate.
    Good luck
    Alan
    Edited 4/19/2007 10:58 pm ET by Alanj
  5. fingersandtoes | Apr 20, 2007 06:33pm | #9
    Many commercial moss killers will damage your asphalt shingles. The best solution, which is recommended by most manufacturers, is to sprinkle Tide with Bleach on the roof. It must be done in sunny weather and left for at least three days before you spray it off. Any moss which is left comes off easily by rubbing it with a gloved hand. Using a pressure washer is iffy as you can remove a lot of the shingle's aggregate, which will shorten its life.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
