Most weatherproof fireplace damper?
NotaClue | Posted in Energy, Heating & Insulation on December 22, 2004 04:03am
For a refurb on a Victorian coal fireplace, about to become a gas fireplace, does anyone have any thoughts about the best way to limit the heat loss through the fireplace and cut drafts?
I assume:
Damper
Glassfront
But what else? And what particulars, if any, for the damper and the glass front…
Thanks!
notaclue
  1. csnow | Dec 22, 2004 10:22pm | #1
    The dampers that seal at the top of the flue work best IMHO.  As a side benefit, they keep the snow and rain out too.
    If you get a gas unit with sealed combustion (combustion air comes from outside), and an airtight housing, that would work too.
    1. Hubedube | Dec 22, 2004 10:29pm | #2
      Dampers are not intended to keep snow and rain out . they are used to control air (heat) flow.
      An approved weather 'cap' on top of the stack is what is used to keep out the snow and rain.
        BillHartmann | Dec 22, 2004 10:52pm | #3
        How is snow or rain going to get past the top of the flue when it is covered by the dampner?And BTW, how are you going to install a cap on the flue when the top of the flue is covered with by the dampner?
        1. csnow | Dec 22, 2004 11:14pm | #4
          This type is both a damper (that really is the term they use) and a cap.
          This type is just a damper.
          One source of many is: http://www.jenningsheating.com/chimney_caps_dampers/fireplace_dampers.htm
          1. NotaClue | Dec 23, 2004 05:27am | #5
            You guys are inspiring with everything that you have at your fingertips and knowledge that represent.
            Thanks!Notaclue
