FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
MT. EVEREST DOOR TRANSITION
Rampside | Posted in General Discussion on May 9, 2008 09:38am
I need to bridge a 1 1/2 in. gap at a doorway transition for a pocket door. The high-point is at the doortrim and does a 90 DEG. down to the closet floor. This happened due to a contractors use of thinset to level a bathroom floor. Or really the framers not leveling the floor joists at installation !
I know I’ll need to cut the door bottom at an angle, of course.
My Biggest concern is, will I need to flare the transition strip further than the doorway opening?
  1. DonCanDo | May 09, 2008 09:57pm | #1
    I can't quite picture this.  The floor is level but the closet floor is not?  Or the 2 floors are at different heights.  I guess the transition strip is not level or you wouldn't need to cut the door at an angle, but what does that have to do with different heights.
    Why not just raise the closet floor height?
    1. Rampside | May 09, 2008 10:14pm | #2
      Both floors are level,but not with each other(MT. EVEREST), and finished. . A transition strip placed in the doorway would need to be at an angle, to transition the 1.5in. height difference. This will require, the already installed (!) pocket door bottom to be cut at an angle (aesthetics).So should I flare the transition further into the walk-in closet instead of what normally would be done, at the door jamb ? This would make the angle of the transition strip less.
      1. DonCanDo | May 09, 2008 10:31pm | #3
        OK, now I got it.
        My first thought would be to raise the height of the closet floor.  If that's not feasible, then I think I would install a level transition strip that reached just to the far side of the door (hence, no angle needed on the bottom of the door) and then a 2nd transition strip from that point down to the floor.
        You can make that 2nd transition strip as wide as seems reasonable, but since it's a closet and there's no trip hazard (so I assume), it wouldn't need to be very wide.  Since it's 1-1/2", maybe you could use a 2 X 4 ripped at an angle.
        aimless | May 09, 2008 10:32pm | #4
        I'm not a builder, but 1.5" height difference doesn't seem like it would have a "what is normally done" for a "transition" because it is a major trip hazard. You might consider putting an orange 2x4 there to protect yourself. Seriously, I wouldn't put a storebought strip there. I'd 1) fix the floor in the closet. It's lower so you can move it up. Even if it is finished, how much does it cost to finish a closet floor vs the lawsuit you get from prospective buyers who take a header when looking at your house? 2) If you really can't fix the floor, I'd put a level jamb under the pocket extending out into the closet and angle it on the other side of the door. I would cut the pocket door level because otherwise it will look foolish and it will probably chip and break from usage on the skinny side. or 3) I'd put a strip of highly contrasting material along the visible edge of floor in the main room, not angled, just a very low step. You can etch your motto into the side, or maybe the words "Plan Ahead".
        1. Rampside | May 10, 2008 12:14am | #6
          It is a walk-in closet. The closet is a prefinished maple hardwood floor over a Warmboard Radiant heat floor. There's no way to do anything but play with the 5 inch space of the door threshold......That sign "PLAN AHEAD" should really be a Bob Marley tune that plays whenever the threshold is passed - "I shot the contractor .....
          1. DonCanDo | May 10, 2008 12:40am | #7
            That paints a whole new picture.  a 1-1/2" trip hazard, even with a sloped transition, is an awful lot.
            I don't think it matters how far into the closet the transition extends.  Anything less than about 2' (a veritable ramp) is going to feel unnatural and possibly be unsafe.  If it's your own house, do what you gotta do, but if it's for a customer, I would be concerned about liability.
          2. Rampside | May 10, 2008 04:15am | #8
            YEP That's the problem!!! Unfortunately there's
            another door about 2 ft. away, on the wall adjacent to the one with the door!!! I guess the only thing to do is to build it to the door jamb width and to the 1.5" ht. ??? What if the transition had an easy arch instead of a hard angle?I can only hope the inspector is in a good mood!!
      3. darrel | May 11, 2008 07:23pm | #9
        yeesh...this seems like trouble. Too short for a step, but too tall for a simple floor transition.What about a full threshold? Maybe along with a transition step at the end of that?
        1. Rampside | May 12, 2008 09:35pm | #10
          I'm going to try to put a threshold molding @ an angle. The inspector seems to be OK with it.
          We'll see when he comes back!!THANKS ALL FOR YOUR INPUT !!!
  2. Danno | May 09, 2008 11:22pm | #5
    Is this a walk-in closet? If not, what's the worry? I may be picturing this wrong, but I would use a threshold that filled in under the door so there's not a gap, but if it drops an inch and a half after that to the closet floor, who cares? No one is walking in and out of the closet, are they?
Managing HVAC Load Calculations
It is imperative for someone at the end of an HVAC installation to commission the job to ensure the efficiency of the system.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
