Saw on an old TOH where a roofer had a tin nail caddy that hung around his neck with a tapered slotted bottom.Nails would slide down pt. first and then u would slide them out from the side.Anybody know where u can get something like this?
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
It's called a nail stripper. Check with your local roofing supply house.
Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
