In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Nail filler in pre-finished flooring
mousejockey | Posted in General Discussion on July 2, 2006 09:37am
I’ve just installed pre-finished Lyptus flooring and need to set the nails and fill the holes along the edges from having to face nail the first/last couple of rows. What is reccomended for that application? I’m thinking one of the crayon type wax(?) pencils.
MJ
Over the Hill? What Hill? I didn’t see any Hill!
    Fonzie | Jul 02, 2006 11:47pm | #1
    I think the wax filler will work fine.
    I want to mention a method we have had success with on a bad spot or bad grain, knot, etc in a prefinished floor.
    We have had success with Bondo that has paste that is light green.
    With some experimenting, add some oil artist color to the paste, then add the hardener (usually red, so this will change the color somewhat).
    When you have a successful color match, mask off the affected area (we use blue tape).
    Install the "color bondo mix", and stay right with it for the "cheese stage", "cut the cheese" (we use a sharp chisel in shear mode), pull the tape, and, done right, it's hard to find.
    The color goes all the way through.
    In your example, though, colored wax.
  2. Floorman | Jul 03, 2006 05:48am | #2
    Go to a paint store and buy a product called Color Putty. Of the many colors available, one will work or you can mix colors.
    1. BryanSayer | Jul 03, 2006 05:50pm | #3
      Color putty is a great product, but the one I am familar with needs a top coat, and the poster is using pre-finished flooring. So he needs something that will cure hard.I'm thinking similar to the other poster, except Abatron and universal tints.
      1. mousejockey | Jul 04, 2006 02:23am | #4
        Thanks to all of you, I'll try the crayon thing first but I do have a couple of spots that I could try the bondo filler and color.
        MJOver the Hill? What Hill? I didn't see any Hill!
          MarkH | Jul 04, 2006 02:30am | #5
          Bondo cures too fast.   Try coloring Durhams water putty.
    JeffBuck | Jul 04, 2006 02:40am | #6
    wax pencil will work.
    I'd see if the latex paste by Bruce Flooring has a match.
    I use a mix of both on all prefinished wood ... flooring and cabinets.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. Snort | Jul 05, 2006 12:53am | #7
      These folks make some very helpful fillers:http://www.hfstaples.com/newlf/pages/Products/index.htm I need a dump truck, baby, to unload my head
      1. dukeofwsu | Jul 05, 2006 01:00am | #8
        Crayon is okay for edges, because there is less agressive cleaning there usually. Hard filler sealed with poly on an artist's brush is better, but a pain.For less filler, pilot drill the tongues in the last rows with a drill sized to match your cleats. Drill at a 50 degree angle or so--the closer to vertical, the easier to drive, bit teh easier to split as well. Hand drive the cleat nail and seat it with a punch. If you goober the nail, chisle a little dado in the upper of the next groove about an inch wide to prevent the nail from causing gaps.DCG Your Neighbor's Contractor LLC"A wrongdoer is often a man who has left something undone, not always one who has done something."--Marcus Aurelius
        1. dukeofwsu | Jul 05, 2006 01:01am | #9
          a couple typos in that, working with nine today...DCG Your Neighbor's Contractor LLC"A wrongdoer is often a man who has left something undone, not always one who has done something."--Marcus Aurelius
Reusable Flood Bags for Fast Bulk-Water Control
These bags from Quick Dam arrive compact and swell to form a protective barrier on contact with water.
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
