Need advice on elevations and framing.
ffmedic0589 | Posted in General Discussion on April 5, 2020 07:17pm
We just got the elevation plans from our designer and I have a few concerns regarding the window placement and height on the walls of the main living room and kitchen area.
First thing I was concerned about is the walls have a top plate of 16′, but the framing is 2×4 construction. I would have thought with that height, it needed to be at least 2×6. He stated that as long as it is supported by the porch roof framing it would be ok. What are y’all suggestions on this?
Second is the window placement on both the front and rear of the living area. There is really no alignment of the upper and lower windows, and seems there would be very few king studs in place. What are y’all suggestions?
I am not a builder and this is our first house we are building, so I really don’t know much and learning as we go.
  1. jlyda | Apr 06, 2020 01:57am | #1
    It will depend upon code in your area. In my area, 2x4 wall at 16’ is accepted structurally if no story above. They do require solid blocking in the wall at common ceiling height. There is issue of energy code where I’m from. For basic construction where insulation is only packed between the studs and not a high performance type of insulation product/design, I would be required to make the wall a 2x6 wall to get higher r value. If you can achieve high r value w/ use of high performance products etc, they will allow for 2x4. My local authority would also require a shear panel on the window wall as it looks like you cannot achieve an uninterrupted 4’ space on corners for continuous structural sheathing.
    Is your designer a licensed design professional? If not, good chance they don’t really know what is acceptable with your code authority to obtain permit and design properly for your area.
    If you are in an area that doesn’t require building code enforcement you may want to get a 2nd opinion from an engineer. If you are going through proper channels and you have a proper functioning building department, the building department will let you know if it’s acceptable. If your designer is licensed, very good chance you can follow his lead.
    So short answer, it’s probably alright, but it depends.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
