Need your opinion about attic ventilation.
I have a small Cape Cod home which I have removed the siding, tyveked it and installed all new construction aluminum clad windows. I will be replacing the siding with cement board. The roof was recently done with ridge and soffit vents. The Cape has two finished rooms upstairs with a small dormer over the half bath. Since the upstairs bedrooms were extremely hot in the summer months. (A New Hampshire located home), I installed a temperature and a humidly controlled automatic fan in the small dormer above the half bath.
The problem. After installing the fan, I later found out that I created a problem because of the ridge vents. I found out that you can not have two types of venting together, as they will “short circuit”. ie, the fan will pull outside air through the ridge vent above the fan, as it is only a couple of feet away from the top of the fan.
My initial thoughts were , that I either have to remove the new fan, or remove the ridge vents.
My new thoughts are as follows, which I would like your opinion on.
The Cape has knee walls, and is insulated with fiberglass insulation from the soffit to the top of the knee wall. (I added foam channels between the insulation and the roof deck). I am thinking of continuing the foam channels up to the ridge vent. This will give me a clear shot from the soffit to the ridge. Add insulation all the way up to the ridge vent, then seal the attic with 1/4″ plywood, both above, and below where the knee wall meets the roof joists. This will allow me to have ventilation from the soffit to the ridge with no leakage into the attic. Keeping the roof deck cold in the winter months and allowing me to use the automatic gable fan in the half bath dormer, which will also be sealed the same way as well.
What do you think. Am I all wet or is this acceptable.
Thank You, Ray
I'm a little confused. You mention two rooms upstairs and a dormer over the half bath, but without pictures or a floor plan I'm not sure if the "upstairs" finished rooms are finished attic space. Is the half bath on the first or second floor? What kind of dormer (shed, doghouse, etc.)? It sounds like the space above the bathroom is continuous with the rest of the attic. The fan you installed vents the attic space above the bathroom, right? It's not a standard bathroom fan that pulls the air out of the actual bathroom, right?
I'm sorry to say there may not be a simple solution. You are basically talking about bringing your attic inside the conditioned space of your house. You'll need to think about moisture movement issues as well.
Maybe post some pictures or a floor plan and we'll see what we can figure out.
-Rich
Why the reluctance to simply add more insulation? It keeps the rooms cooler in summer and warmer in winter.
The air channels are also a good idea, but don't skimp on the insulation.
I stopped reading at your new idea.
A fan in an attic is used to expell hot air. This requires new air to replce the expelled air. This air, in your current design will come from the ridge vent.
If you did not have a ridge vent, you would need a window across the attic to get the make-up air.
Ridge vent or widow; same dif.
Even with ridge vent you are pulling air from along the legth of the ridge, not just the first few feet - if you have a desent attic fan.
Frankie
Exasperate your vegetables until exhausted; disturb your chestnuts in milk until queasy, then disappoint.
Arabella Weir as Minty Marchmont - Posh Nosh
