In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
New Linoleum Floor Over Vinyl
KLawler | Posted in General Discussion on November 18, 2002 05:47am
I am planning to have real linoleum installed in my kitchen and a small back entrance. The existing floor was laid in 1964. It is a vinyl sheet product that my flooring installer says is asbestos backed.
He has given me two options. Remove and dispose of the flooring myself or he will lay 1/4″ plywood over it and then lay the linoleum. The doors are all balsa core and taking a 1/2″ or more off of them would blow them apart so the second option doesn’t really work. I don’t like the first option either. Why can’t linoleum be installed directly over the vinyl?
Real linoleum has one major drawback that I can see, discoloration. Armstrong (they now own a linoleum manufacturer) makes a product that they call a polish that supposedly protects against appearing dull or faded. Does this mean that it stops the sun from discoloring the floor? I also understand the seems on a linoleum floor really stand out. Are there any opinions about linoleum discoloration and seem issues?
  1. RW | Nov 19, 2002 01:18am | #1
    Option 1 is probably simpler than it seems. You can have the whole thing out in less than ten minutes if you have access to a skill saw and a sawzall. Just cut through the underlayment and pull. No need to get crazy with it, just cut where you have to to get the flooring out. Another piece of ply and you're done. The installer probably just doesn't want to deal with removals (common) and if he does, in fact, believe it's asbestos, he probably can't deal with it legally even if he wanted to, but you can as the HO. As to why not lay 1 over another, it's done all the time, this guy just probably takes a little pride in workmanship. It's like putting three layers of asphalt on a roof. You can do it, but it's a lousy idea and shortens the life of the roof. Your new linoleum should have a plywood backing to lay on. If it's too soft, you'll start nicking it up with things as inconsequential as high heels.
  2. chiefclancy | Nov 19, 2002 05:32am | #2
    Another reason why laying the linoleum right over the vinyl may have to do with the compatibility of the adhesive. I can't speak for linoleum but I've had problems with installing certain sheet vinyl products directly over anything except new ply, as the adhesives have reacted and stained through the floor from below. The most important thing is to follow manufacturer spec; if Armstrong gives you the go to put their linoleum directly over vinyl (and will warranty it) then go for it.
    FWIW, Armstrong has great tech support...
    Andy
    1. suntoad | Nov 19, 2002 09:55am | #3
      Or not. Perhaps the floor installer knows the underlayment is glued down.  Yikes!
      Taking up glued down particle board underlayment can be like removing latex paint with your fingernail.  It can take days.  Worse, its probably been stapled as well.  Some glues are so tenacious that I've had the plywood subfloor delaminate rather than relinquish the glue and underlayment.
       If it IS glued, best bet is to leave it there and lay the new floor over it.
Schneider Electric Recalls Line of Electrical Panels
The QO Plug-on-Neutral Load Centers can overheat causing burns and fire hazards. Consumers should contact Schneider Electric for inspection, repair, or replacement.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
