New Sewer Line for Granny Unit
yojimbo | Posted in General Discussion on September 30, 2006 07:54am
Putting together costs for building a “granny unit” behind a clients house.  The structure is about 25 feet away from the main house in the back yard.  The main house is on city sewer.
 The only way I see to tie into the the existing sewer line is to install a sump pump at the “granny unit” and then run a 3″ line to the main house and tie into the sewer line there.
I guess you could also use a macerating toilet, and install a leach field for the shower and the sink, but that sounds expensive.
    Matt | Sep 30, 2006 08:26pm | #1
    I'm guessing that the finished floor of the proposed "granny unit" is below the FF of the main house and likewise for the main soil pipe exiting both structures?
    I'd be surprised if any kind of leach field was allowed in an area that has city sewer.   Also, just as an FYI I think that sewage injection pumps are often connected to out-feed pipes of a smaller diameter than 3" - say 2.5".  I may be wrong about this, and I'm sure someone will correct me if I am.   Also, a backflow prevention valve would have to be incorporated.
    Really, you need to get with a local plumber who is well versed in the local codes and restrictions.
      BillHartmann | Oct 01, 2006 05:08am | #4
      "Also, just as an FYI I think that sewage injection pumps are often connected to out-feed pipes of a smaller diameter than 3" - say 2.5"."Actually mine uses 1 1/2". But it is a force main system. The main is only 4" for about 150 homes.IIRC for basic sewer ejector pumps they use 2" lines.
        IMERC | Oct 01, 2006 06:50am | #6
        the pump I have on the shelf is 1-1/2"...
        can't remember where it came from but it's been the for some time..
  2. Dave45 | Oct 01, 2006 01:19am | #2
    There may also be a problem connecting the new sewer line to the existing line unless it's already oversized.
      Matt | Oct 01, 2006 02:06am | #3
      Right - but a 4" line will service - whatever.  When doing apartment construction, we had 4 units with 8 toilets, etc feeding into one 4".  I was a little surprized but the plumber told me that a 4" line can handle a heck of a lot of sheet :-)  Two 4" fed into a 6".  an 8" services the whole apartment community.  A rule of thumb someone told me one time - 3" line max 3 toilets.  4" line 4 or more toilets.
      Here, in new single family construction it is always a 4" line going out to the street.
      1. ponytl | Oct 01, 2006 07:53am | #7
        engineer spec'd a 4" line for my 20unit project... about 100 outlets  ie showers, sinks washing machines ect...
        I questioned it and it was explained to me.... high flow is good... with smaller pipe lots of stuff flow'n thru it HIGH FLOW ... vs large pipe and low flow... where you have the problem of liquids pass'n/leave'n the solid stuff behind....
        worked for me since i had a 4" main come'n in anyway saved me about 10k
        p
  3. jjones | Oct 01, 2006 06:22am | #5
    maybe a composting toilet  and pump laundry shower sink s
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
