In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Noisy FHA Duct
GeorgeP | Posted in Energy, Heating & Insulation on December 19, 2010 06:35am
My FHA heating duct in the basement of a rental unit is pretty noisy with a vibrating, rattling sound.  The ducts seem to be tight to the ceiling joists but if you push on the bottom of the duct the rattle stops.  Any idea what could cause this rattling?  I was thinking that maybe something is inside the duct, like a metal screw (that’s kind of what it sounds like) and was considering cutting a hole in the bottom of the duct to clean it out, then patch it with an sheet metal patch.  Is that as bad an ida as it sounds?  Befofe I did that I’d like to eliminate other possibilities.
Thanks,
George
  1. calvin | Dec 19, 2010 06:44pm | #1
    How's it hung? tabs or straps?
    And is there a flexible boot at the furnace/duct connection?
    If strapped, shove a shim in there to see if it just needs a bit of tightening.
    Couplers might also rattle (doubtful), but can be shimmed to find out.
    Flip dampers usually can be tightened (if that's the source).  Tighten the nut.
  2. DanH | Dec 19, 2010 06:56pm | #2
    I doubt that it's something loose inside -- for that to be the case the amplitude of the vibration needs to be above 1 G, and that's more motion than you'd typically see in a duct that wasn't directly attached to the air handler.
    I would guess that it's "just vibration", perhaps the duct rattling against something next to it or above it, or simply microscopic "oil-canning".  See if you can jamb something up next to the duct to stop the rattle.  Or, as I've done in some cases, you can glue something like scrap vinyl flooring or self-stick floor tile to the duct to dampen it.
    1. cussnu2 | Dec 20, 2010 09:52am | #3
      Something perty like pink with red roses would be nice.
Adaptive Rainscreen Siding Clips
This fastening system from Nova USA Wood Products accommodates natural wood siding expansion and contraction.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
