Point your browser to www.ce.kth.se/bim/bphys/ and down-load copy of the paper “”Moisture in Constructions with Loose-Fll Insulation and no Vapour Barrier.” GeneL.
WHY?
What is it that's so important that you decided that it was a must read and required that you command us to download it?
Gabe
*Gene - you're probably better at reading these than I am but are they really using less than 3/8" (9mm)gypsum board for the exterior sheathing?Also, do you know what density they install the cellulose at?I know that when I lived in Sweden for a year in the late 60's that they were using much more energy-conscience house building practices than most of what is built here today so I'm not surprised to see such extensive research being done there. Thanks for the reference.
*Gene,
View Image © 1999-2000"The first step towards vice is to shroud innocent actions in mystery, and whoever likes to conceal something sooner or later has reason to conceal it." Aristotle
*Gabe. Download the paper and see for yourself. It may or may not be of interest or of use to you. Given the many discussions re cellulose as a VDR I thought their findings might be of interest to many on Breaktime.Bill. I'll hav to get back to you on those questions.Joe. Good hearing from you. There is another paper you might find interesting--I have a copy of it here somewhere: "Moisture Conditions in a North Facing Wall with Cellulose Loose fill Insulation: Construction with and without Vapor Retarder and Air Leakage." Published in Volume 19 of the Journal of Thermal Insulation and Building Envelopes. Authors: Hagentoft and Harderup. GeneL.
*Gene...This thread should be in the energy folder...I would love to read the articles you are quoting cause I feel homes that breath naturally may be healthier homes and DP may be part of the solution...near the stream,ajRead Kevin's article in crawlspace venting...Joe, glad to see you reading DP info...
*Bill. There is no mention in the paper of the installed desnity of the cellulose. The authors noted that "There are strong indications [of]... ongoing settling of the loose fill insulation in the roof construction..."The GWB seems to be 13 mm--approximately 1/2-inch. GeneL.
*adirondackJack, Mea culpa.You can read this paper by downloading it.I had posted a reply to Gabe, Bill and Joe but it doesn't show up. Who is Kevin and where did he post or write on crawl space ventilation? Gabe. Download the paper and see if it is useful or not. Given the amount of pro and con discussion on cellulose being a VDR, I believe any information on the subject is welcomed by most posters on Breaktime.Oh yes, the research was done in private, occupied residences--3 houses. Joe. Good hearing from you. Another useful paper is the second reference given by the authors. I should have a copy soon and will see what I can do about making it available...copyright issues. GeneL.
*Gene...I read all quickly and it sounds like they are using formulas to predict mold...I didn't find any info that said b there was mold.I concluded nothing either for of against Cells...and find the external condensation plane to be the most important factor in controlling the health of this wall...A breathing wall built right would evaporate moisture and store moisture at levels below mold growth...At least that's what I think is trying to be acheived...Fred always said keep the moisture down in a home...I feel that way too...It's very much site and occupant influenced along with the building practices used in the construction. My few moisture dealings were real people caused...boiling water for hours daily with no lids and no fan running...hours of shower use...wet crawls...near the stream,aj
*Gene, I only had time to review them quickly and while it's interesting reading, a lot of it is not relevant to real situations here. Construction in scandanavia is considerably more controlled than here. A lot of apples and oranges here. You could misinterpret just about anything in these papers and substantiate with formulaes that don't apply here.Gabe
*Gene - I think the exterior sheathing was shown as 9 mm gwb. The interior was 13. I was more interested in the use of gwb as exterior sheathing with no other indication of materials resisting shear. They may strap with steel or plastic bands. I don't recall Scandanavia being an active seismic - but they do get strong winds and very deep snow loads on roofs.
*Ajack, I know now not to let you read anything of importance. . .
*Gene,
*Bill. Mea culpa. 13 mm was the inside and 9mm the outside. Joe. Thanks for the comments. The most recent paper--1998 on this subject, "Organic Insulation Materials: Humidity and Necessity of a Vapor Basrrier,"is found on page 109 of the Thermal Performance of the Exterior Envelopes of Buildings VII, December 1998. By the bye. Joe Lstiburek argues that "cellulose is not a VDR." GeneL. But then, Harold Orr's finding about cellulose insulated houses built in 1909? in Canada give one pause to reflect. GenerL.
*From b your quote, I'm reading, I quotei "temperatures feasible for mould growth"...I am noting the fact that b no mould was found...I also feel there are many successful installs in our Glens Falls area... I know of no failures other than those I mentioned above...Sorry you still feel the need to personally attack me...but that is what we all have come to expect of you...I will not be posting back to you about this...Pretend I did if it make's it more fun Fusco...near the stream having my shorts torched semi-annually...flame away...aj
*A_jerk,
*Gene...What do you think of DP cells in Upstate New York?near the stream having yet to observe local problems...aj
*A_jerk
*Aj. The first energy efficient house I built--1977-- was insulated with 3.5 lbs/cu/ft cellulose.The term Dense/Pac--coined by Richard Munson?-did not exist at thattime. I continued to use cellulose in the houses I did all over the country including NY state, and Canada. I later changed over to sprayed-in polyurehtane(PUR), but blew-in cellulose in the attics. See archives on my use of PUR. GeneL.
*Gene...So does DP work and does it get moldy and does it need poly and does it perform better than fiberglass?Lots of questions, near the stream,aj
*Thanks Jack, I'm laughing out loud.P.S. - don't flame me or I'll give people your real name and address!-Rob
*AJ. The archieves will answer many of your questions. DP works, but so does FG if installed properly. The Saskatchewan Conservation House proved than more than 20 years ago. I have heard of mold/fungus forming on cellulose, but do not know if the cellulose was treated or not. Was this posted on BT? I personally have never seen this in 20 years. But it doesn't mean it can't happen. GeneL.
