In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Notching corner studs?
mquinn84 | Posted in General Discussion on March 28, 2010 04:01am
I am adding electrical circuits to my garage in order to use it for shop space.  Is it okay to notch corner studs to get wire around them?  Studs are 2×4 and going above through the top plate gets me into the roof rafters.
  1. DanH | Mar 28, 2010 04:14pm | #1
    Usually, if you study it a bit, you can drill a couple of holes rather than notch.  Drill one from each side so they intersect, with the drill held tight against the sheathing, so you're getting the best angle possible, rattle the bit around a little to enlarge the hole, and then bend a hook in the very end of the romex before you fish it through.
  2. Clewless1 | Mar 28, 2010 08:14pm | #2
    What Dan said ... also ... I THINK it's OK to notch ... just put in a protective plate on both sides, too.
    1. DanH | Mar 28, 2010 08:27pm | #3
      Yeah, nail plates are probably a good idea even if you drill.  You are apt to get the wire a little close to the face, and there will be a fair number of nails/screws going into those studs.
  3. Scott | Mar 29, 2010 12:24am | #4
    We're all assuming this is old construction, right?
    If it's new construction in an unsided garage, you can bore holes from the outside through the sheathing and studs.
  4. calvin | Mar 29, 2010 07:21am | #5
    The quandry
    You need to get the wire near the center of the studs to be safe.  To do that, you compromise the maximum allowable depth of a notch cut into a bearing wall which is 25% the depth of stud.  You should drill your holes.  Using a nail on plates for protection only takes care of the wire covered by that plate.  It's still possible to nail or drill that wire if not fully protected.
    Have I done what you propose?  More than likely, but I don't recommend it.
    xxPaulCPxx | Mar 29, 2010 12:35pm | #6
    You could also do surface mount and forget notching alltogether.  Easier to change later too.
Adaptive Rainscreen Siding Clips
This fastening system from Nova USA Wood Products accommodates natural wood siding expansion and contraction.
  • Cordless Drywall Cut-Out Saw
  • Podcast 461: Adding a Screened Porch, Insulating a Raised Addition, and Preventing Termites in Exterior Foam
  • Decompartmentalizing a 1940s San Francisco Home
  • Upgrade Your Window Air Conditioner
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Tool Guide 2022
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
