I am an experienced DIYer and am considering installing pre-finished oak flooring in my living room (replacing carpet). Area is about 375 sq. feet on first floor over a dry basement. Subfloor is 3/4″ T&G plywood over 16″OC floor joists. In looking at the Bruce products recently I noticed their laminated flooring products can be installed “floating” or nailed down. I am somewhat confused that you could install this either way. What do you pros out there think is the best way to go?
snrea,
First of all, you may want to consider your choice of flooring. Laminated has it's advantages when trying to minimize changes in elevations, relative to other other types of flooring on the same level, but from a wear standpoint, a solid hardwood floor (pre-finished or site finished) is the way to go. A laminated floor is only good for one or two sandings and it's time to tear it up and replace it. A solid wood T&G floor will last a lifetime.
In general, I'd recommend floating laminates over radiant heat, otherwise I'd prefer to nail down a solid 3/4" strip product.
If the idea of avoiding the sanding, staining (if desired), and sealing that unfinished solid strip flooring requires does indeed appeal to you, that may be a good reason to go with it. I do feel, however, that in your installation, a solid product would be superior to an average laminate.
Here's a link that may give you some additional info to help you out in your installation.
Congrads on ditching the carpet, I hope your project turns out well.
I am an experienced DIYer and am considering installing pre-finished oak flooring in my living room (replacing carpet). Area is about 375 sq. feet on first floor over a dry basement. Subfloor is 3/4" T&G plywood over 16"OC floor joists. In looking at the Bruce products recently I noticed their laminated flooring products can be installed "floating" or nailed down. I am somewhat confused that you could install this either way. What do you pros out there think is the best way to go?
