In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
OSB not holding paint
Jigs_n_Fixtures | Posted in General Discussion on December 3, 2010 12:02pm
I have some buildings constructed in 1984 that have an OSB panelized siding that looks like T-111.
The stuff will not take paint.  We have tried different primers, and top coats but the piant just peels off.
I remember reading something about this problem years ago, but can’t remember what the solution was.
Does anyone else remember more details?
  1. calvin | Dec 03, 2010 12:24pm | #1
    If the peeled paint lost it's bond........
    right down to the sheathing, I would think moisture migration is "pushing" it off.  Is there any paint left on the paneling below that peeled stuff?
    1. Jigs_n_Fixtures | Dec 03, 2010 07:03pm | #2
      it held for years,
      I don't think moisture is a problem, as the OSB stuff is still in good shape, and water seems to bead off it.
      I think the problem is that the surface was pretreated with something so that the water based paint didn't swell the flakes.  The original paint lasted fifteen to twenty years.
      When we tried to repaint it we ran into problems.   And, I'm trying to figure out a solution short of pulling of the old siding and replacing it with Hardy Panels.
      1. DonCanDo | Dec 03, 2010 08:29pm | #3
        Original paint?
        Can you tell what the original paint was?  Maybe it was an oil-based paint?  Have you tried an oil-based primer?
        It just doesn't make sense that it could be painted once, but not again.
  2. DanH | Dec 03, 2010 08:39pm | #4
    Some OSB has essentially a wax coating on it, for weatherproofing during construction.  The stuff was supposed to be covered with siding or whatever, not painted, so no consideration of paintability was taken.  Though your OSB apparently was sold as exterior siding, I'm guessing it got that same treatment -- probably a fly-by-night supplier.
    I would guess that your best bet for getting a paint bond would be to use an alkyd or oil primer, maybe after first washing with "liquid sandpaper" to remove as much wax as possible and give what remains some "tooth".
    1. DonCanDo | Dec 03, 2010 09:15pm | #5
      I was thinking about that, but then how did the original paint stick for 15 years?
      1. DanH | Dec 03, 2010 09:35pm | #6
        Probably the "just right"
        Probably the "just right" primer was used -- something that bonded to the waxy coating and provided good "tooth".
        What types of primers have you tried?
Designer Kitchen Cabinets on a Budget
This Danish manufacturer has found a way to bring modern, architect-designed cabinetry to the masses.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
