where can I find how much gas / energy they use?
And are there electric look alike bulbe that flicker?
From not venting your bathroom to not venting your siding, understanding how things go wrong is the first step to getting them right.
Good question, one I'm keen to see an answer for.
Well, I'm not sure I've ever seen the manteled gas yard lamps ever flicker. However, any decent supply house ought to be able to connect you with either standard (medium) or candelabra-based lamps that flicker. Now, that "flicker" is an odd thing in that lamp. It's very voltage sensitive; and not very bright, in lumens. I want to remember that they only run about 15-20W, though--which is not a lot of output for a person's path up to the house.
