over counter light wiring
CaseyR | Posted in Construction Techniques on November 16, 2006 08:10am
I am planning to install low profile T5 fluorescent lights over the counter I soon will be installing in my kitchen. I am planning to link them together with BX cable but I was curious if it was acceptable practice to link them with Romex since, while exposed, they would be well out of harms way on the top of the cabinets.
Second question on standard practices: do installers normally notch the sides of the cabinet where they extend above the top of the cabinet to better hide the cable or is that considered poor form and the cable is just run over the 1 inch or so protrusion even if it might be partially visible?
  1. philarenewal | Nov 16, 2006 09:00am | #1
    Code where I am -- anything less than 7' above the floor must be protected.  If the wire is exposed, must use armored cable or conduit.
    For your second question, the way I do fluorescent under cab is to notch (or drill a hole if the back of the cab comes down low enough) and mount the fixture under the cab up close to the wall so it touches the back of the cab.  The romex clamp attached to the back of the fixture "nestles" into the notch or hole.  That way, no wire is exposed and romex is OK, and no wire or notch or hole shows behind the fixture.  Maybe there is a better way but that's the way I do it.
    "Let's get crack-a-lackin"  --- Adam Carolla
    1. calvin | Nov 16, 2006 02:33pm | #2
      Like phila, I hold the strip lite fixture to the back of the cab and loop out of the wall with romex.  In/out of the fixture to the next one (on rare occasion not enough room to make up that connection in the fixture-in that case separate runs to each light).  If you run end to end exposed, you really should sleeve it or use sheilded wire.  Some of the indiv. fixtures have connecting wiring that is more like fancy lamp cord (round).  In that case you drill a hole through the joined cabinet ends, don't loop under.  Or, you could cover with some ripped up chase from cabinet wood.A great place for Information, Comraderie, and a sucker punch.
      http://www.quittintime.com/
      1. Dunc1 | Nov 19, 2006 08:19am | #3
        Installed some fluorescent units that have tubes about 1/2 inch diameter. there are various lengths (about 12 inces to 24 inches) Really neat system: each unit comes with a coupler to allow connecting multiple units together (over a long counter span).As well they offer a "junction box" that mounts at the wall exit for the direct wire power. This prevents any exposed cable. Even has an on-off switch if there is no master switch.Packaging long gone so have no brand name.
    BillHartmann | Nov 19, 2006 08:50am | #4
    The basic NEC requirement is that NM can be run exposed if follows the building surface.
    But if SUBJECT TO DAMAGE then it needs to be protected.
    Now what is subject to damage is subject to the interpretation of the AHJ.
    In my opinion the couple of inches along the bottom of a cabinet would not be subject to damage.
    But if it is then one method of protecting it is a guard strip. A wood strip could be used.
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
