Paint bubbles on door
| Posted in Construction Techniques on October 6, 2004 05:46am
Friend/customer has an expensive set of front doors, pair of 3-0x8-0 mahogany.  They face mostly west with a short two-story porch overhang … maybe 6 ft.  They were varnished for most of their life, but a couple of years ago she had the outside painted black … the insde is still varnished.  The outside has been refinished about three times cuz the paint develops small bubbles and blisters.  I did it the last time, using Sherwin Wms Duration.
I sanded the outside lightly, although inn some places the paint easily came off to bare wood, and applied 1-2-3 primer.  This was done in June, I think, when it was very hot & dry.  Now I notice that there are several small bubbles again.  The house is always air conditioned or heated, so the humidity should be pretty stable.  There is one crack in a panel joint, maybe 1/16″ x 3″, but the bubbles are in several places, even in the upper panel where there are no visible cracks.
Help.  Any ideas why the bubble appear, and how to avoid them next time?  Before you ask, the doors will always be black, so that’s not an option.
Whenever you are asked if you can do a job, tell’em “Certainly, I can!”  Then get busy and find out how to do it.  T. Roosevelt
  1. UncleDunc | Oct 06, 2004 03:53pm | #1
    Didn't we go through this once already?
    The paint bubbles because it gets too hot.
    There is no way to prevent it. If the customer insists on that material and that color in that location, the very best you can do is shorten the maintenance interval so you repaint it before it starts to bubble. If you've been doing every three years, try doing it every other year.
    Edited 10/6/2004 8:54 am ET by Uncle Dunc
    1. FastEddie1 | Oct 10, 2004 07:00am | #2
      yes, we discussed these doors when I was doing the work.  This is the first time I refinished them, they wewre done previously by other people.
      Ok, maybe the heat is doing it.  But why wouldn't it blister all over the door?  There's maybe 10-12 aspirin sized blisters near the middle.
      Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
      1. RW | Oct 10, 2004 07:14am | #3
        Ed - complete stab in the dark, but it's a thought. Varnish. Exterior. That means long oil. Soft squishy stuff. Latex over something with a high oil content.
        Agree the heat doesn't help. But I'm having a hard time (not seeing it) swallowing that heat alone - unless it's trapped by a storm door, will do that. Maybe it will. To me, bubbles in a finish like you describe is telling me something behind the finish is popping it out. You see that kind of thing when wood that was damp gets painted. Gee, the paint doesn't stick, wonder why. Maybe the heat is enough to encourage off-gassing to some degree, even if the varnish is well aged.
        As far fetched as it sounds, I've run into stuff that got oil furniture polish on it ten years ago and today you can't make some finishes stick to it. To cure that, I lean on vinyl sealer after washing the surface down. So far, nothing I've done that to has had a recurrance of bubbles. Ok. But have I put it on an exterior door. nope."If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man." - Mark Twain
  2. alias | Oct 10, 2004 07:09pm | #4
    go to the source.. http://www.homesteadfinishing.com
    "expectations are premeditated resentments"
    Edited 10/10/2004 12:13 pm ET by the bear
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
