In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Painting an aluminum awning
Rebeccah | Posted in General Discussion on February 8, 2008 02:02am
Doing cosmetic work to sell my home in Oakland CA…
The house is a 1919 bungalow, with later addition of aluminum awnings over the living room window and front and back porches, and ugly aluminum support columns (kind of a swirly sort of bent-aluminum design between two 1.25″ square tubes for each column) for the one over the front porch. Current house color is pale pink with white trim and awnings, red sidewalks and driveway, light colored gravel on the roof. There is a wrought-iron railing for the front porch and stairs, which was painted a couple of months ago (we’re doing the window bars now) with Rust Bullet, which is a moisture-cure urethane coating and is silver in color.
The house is badly in need of an exterior paint job. We’re going to change the wall color to something more curently popular – probably a “warm grey”, that is, something sand- or khaki-like in color. We’ll stay with white trim.
The question is what to do with the awnings, which are filthy. The awning over the front porch provides necessary shelter from the elements, so ugly as it is, it stays. The house would look unbalanced if we took off the awning over the living room window and left the one over the porch; plus, the neighbors on either side have awnings over their front windows, so it fits right in.
Options:
1. Just wash the awnings and leave it at that.
2. Paint the awnings with the same semi-gloss, white paint that we’re using for the trim (Behr premium exterior acrylic, supposed to be primer+paint in one).
3. Paint the awnings with the same Rust Bullet coating we’re using for the railings and window bars that actually need the rust protection ($$$).
4. Something else.
Questions:
1. Will exterior acrylic paint stick OK to aluminum? Does it need a special primer?
2. Opinions about white vs silver color, vs something else? I’ll try to dig up a photo of the front of the house and add it to the thread. The realtors I’ve interviewed would want the awning to come down, or at least no attention drawn to it.
3. One of my fiance’s friends has an airless sprayer and supposedly knows how to use it, so we’ll be spraying the stucco when we get to that part. If we paint the awnings, should we spray them or brush? I don’t think we’ll be able to use a roller, due to the way the metal is corrugated. We definitely won’t use the sprayer if we go the Rust Bullet route — that stuff can’t be removed once it hardens, and these guys don’t take that great care of their tools.
4. If we paint the awnings, should we paint both the top (outside) and the bottom (inside), or just the top (outside)?
Any input greatly appreciated!
Rebeccah
  1. Rebeccah | Feb 08, 2008 02:26am | #1
    These photos are from when I bought the house 4 years ago.
    Edited 2/7/2008 6:42 pm by Rebeccah
  2. renosteinke | Feb 08, 2008 04:56am | #2
    In a word ... DON'T
    Painting such things has always bee problematic. If you want the best results, see if you can get them powder coated. Failing that, take them to an auto body shop for painting with a proper paint for the material.
    1. Rebeccah | Feb 08, 2008 05:10am | #3
      I'll take that as a vote for "wash only." Those columns are already painted white, though (previous owner).The one neighbor's awning is painted. The yellow and blue one, looks like a circus tent. I'm not sure about the neighbor on the other side. It's a dark color, but it may have originally been that way.Rebeccah
      1. alanj | Feb 08, 2008 06:53am | #4
        My experience with prepainted aluminum has been very good. I should add that I am not a painter, but have seen many paint jobs that turned out well. Even alum. siding paints quite well.From what I've seen, a powerwash, let it dry, and spray on acrylic.Thinking back to a job at least six years ago. No problems, No call backs.
        1. Rebeccah | Feb 08, 2008 06:58am | #5
          So, that's one vote for "wash only" and one for "spray on acrylic".Rebeccah
            Kurt99 | Feb 08, 2008 06:30pm | #7
            I would expect it to paint well with the acrylic paint. Aluminum siding paints well with acrylic paints. I will second, or third or what ever the importance of prep. The oxidized layer of paint and attached dirt needs to be removed. I would recommend TSP and a scrub brush then rinse well. Two minutes with a power washer is not going to cut it.Should you paint the bottom side? Will you look out the window and say it looks like ####? Or will it clean up and look decent? Paint if it looks bad after cleaning.Spraying has the potential to look smoother than brushing and not counting equipment clean-up time is much faster. It can be tricky to spray irregular surfaces to get everything completely covered without getting to much in some spots so you get runs and drips. Spraying with irregular touch up with a brush to catch the drips almost always looks worse than brushing the whole thing. You also need considerable care and or masking to keep from painting everything in sight. The bottom line, I would probably brush the awning and I certainly would not attempt spraying it if you do not have a fair amount of experience with a sprayer.
          2. Rebeccah | Feb 08, 2008 07:28pm | #8
            OK, I'm getting the picture.The amount of work it will be to paint it is not worth the payback in terms of improved appearance of the house to sell faster. I'm not convinced that painting it will help it sell for any more money. We'll wash and scrub with TSP and probably just be done with it. The guy who owns the sprayer is hardheaded and likes to cut corners. I just had a talk with my fiance about letting him not mask the windows while painting the security bars. I'm tempted to roll the stucco walls, because I sure don't want overspray on the neighbors' cars and houses (or on my gardens, either).Rebeccah
  3. IdahoDon | Feb 08, 2008 09:13am | #6
    You can paint the awnings, but you may not want to go through the trouble it takes to do it right.   Getting the surfaces prepped in the joints and cracks is very hard and most repainted awnings I've seen suffer from pealing paint, which not surprisingly starts in the cracks and joints.
    You don't want to use house paint, but rather an oil based enamel, preferably not out of a rattle can.  The key to making it all work is surface prep and a suitable primer (mumble this over and over as many times as needed while visiting your local paint store).
    You'll want to get the old oxidized layer of paint off and get down to solid paint or bare metal, whichever comes first.  Then use a metal wash primer if any bare metal can be seen, followed by a good quality general purpose adhesion primer.  After that top coat with whatever color you wish.
    Your best bet are the industrial lines of paint or very similar automotive products.
    If you commit to proper surface prep the cost of good primer and paint can set some people back a bit.  $50 a quart for an industrial paint or primer isn't uncommon.  There is no free lunch, and the very best paints are also the most expensive.
    Stay away from two part polyurethane paints unless you can rent or borrow proper breathing equipment.  This stuff is tops however, and most aluminum aircraft are painted with it.
Cutting Small Tile
Cutting small tiles comes with extra challenges. Learn how a simple addition to your saw's sliding table can make cutting small tile easier.
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
  • Coastal Home That Mimics Nature
  • A Sturdy Rail for Outdoor Stairs
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
