Are many of you Paslode Impulse owners having trouble with the gun not firing on command; just hums and the smell of gas when you pull the trigger, the driver not retracting on completion of a drive, etc. I have all of these and the gun has only fired 1200 or so 2 1/2″ nails. Tried the spray cleaner with no help. Also, two canisters of gas for only 1200 nails fired doesn’t match their spec. They say like 2400 nails per canister. Did they bring the gun out too soon, like to make the money anyway. I am not happy with Paslode and I suspect that the gun will spend more time in the repair shop than on my jobs. GW
There's a constant source of clean water for you to use, and all you have to do is collect it.
Are many of you Paslode Impulse owners having trouble with the gun not firing on command; just hums and the smell of gas when you pull the trigger, the driver not retracting on completion of a drive, etc. I have all of these and the gun has only fired 1200 or so 2 1/2" nails. Tried the spray cleaner with no help. Also, two canisters of gas for only 1200 nails fired doesn't match their spec. They say like 2400 nails per canister. Did they bring the gun out too soon, like to make the money anyway. I am not happy with Paslode and I suspect that the gun will spend more time in the repair shop than on my jobs. GW
