Patching a tin roof…
FrankFromNC | Posted in Construction Techniques on September 15, 2005 05:23am
Greetings!
I’m renovating a house with a tin roof. There’s several empty nail holes which need to be patched to prevent leaking. What’s the best way to do this?
Thanks,
Frank
    Dinosaur | Sep 15, 2005 06:08pm | #1
    You can try to find a supplier of the old lead roofing washers to slip onto some 1¾" roofing nails, but good luck on that one. I can't find them here at all. So I think your best bet is going to be to run some roofing screws into those holes. Use the kind of screw that comes with a rubber washer already on it. Any supplier who sells metal roofing will have these. They're available in colours to match the roof colour.
    If the nail hole in the wood under the tin is blown out or otherwise too big for the screw to bite, shove a few toothpicks into the hole first.
    If the nail holes in the metal are too big for the screwhead and washer to cover, you'll have to squirt some butyl caulking into each hole. This is a silver-coloured product and won't be very visible on a galvanized roof as would black roof patching compounds. It also stretches better so the expansion of the metal on hot days won't break the bond. It should be available from metal-roofing suppliers, too.
    Dinosaur
    A day may come when the courage of men fails,when we forsake our friends and break all bonds of fellowship...
    But it is not this day.
    1. FrankFromNC | Sep 16, 2005 04:19pm | #3
      Thanks for your help!
  2. seeyou | Sep 15, 2005 07:38pm | #2
    I've had good success using Geocel 2310 or 2315 brushable in conjuntion with 2300 caulk to fill larger holes. If the hole is too large for the caulk to fill, rivet a small piece of similar metal over the hole and coat with the brushable. Geocel products are normally availabe thru roofing supply houses.
    Birth, school, work, death.....................
    1. FrankFromNC | Sep 16, 2005 04:19pm | #4
      Thanks a bunch!
  • A Closer Look at Smart Water Leak Detection Systems
