I’ve had this PC 7406 4.5″ angle grinder for many years, and it it had performed flawlessly despite a lot of dust, hard use, and abuse. Still no signs of arbor play or slowing down in its old age. One of my favorite tools.
Recently, I went to remove a threaded grinding disk, and the arbor lock gave way under the load. I did not think the load was particularly excessive in this case.
I took it apart, and found that the metal gear housing had cracked badly on the inside around the arbor lock pin, and part of the wall that holds the top spindle bearing broke away with it.
I ordered up a new housing, bearing, arbor lock parts, and will be out about $30 repairing it.
Anyways, if you have this tool, I suggest using a (thin pattern) wrench instead of the arbor lock when removing threaded wheels. Actually, I plan to use the wrench instead of the arbor lock all of the time.
Don’t let it happen to you!
Thank you , but too late. I had the same happen last yr. I junked it..oopps. I didn't think it was worth replaceing.
I can useually unscrew the cup brush or any threaded fixture by hand, but one time she locked up too tite.
I bought 4 from HF @ 17.99 a pc. Now I just leave the attachments on..LOL.
The Morphine s eems to do no good at all..I'd run all the way if I would not fall...
