In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Pella Bay installation
mnhunter2 | Posted in General Discussion on August 31, 2004 08:25am
Will be installing a 8′ Pella bay window this weekend and I was wondering if there are any tricks to getting the job done right.  This will be my first bay install but have done lots of anderson windows.  Will the cables hold the weight over time or should I look at some sort of underwindow support?  The window will be going into a remodel project and it is rough framed in the old windows place.
  1. build1234 | Sep 01, 2004 12:10am | #1
    My run down...
    Cables are ok but I supplement with supports underneath. What I use depends upon the siding on the house, but mitered 2x6's work well if run from the outside of the bay to some convenient point against the house- like the band joist or studs. This is especially important if people are going to use the window as a seat.
    I always insulate under the window because they get cold. However, don't forget to leave space for getting to the adjusting nuts, should the cables stretch or loosen. Who knows if these will ever actually be used but I leave the access anyway. Rigid foam works pretty well for insulation, then I cover it with plywood and drill holes for access with a deep socket.
    If you build a roof for the bay, look around for articles on the proper way to do it. Aesthetically, it makes a difference to get the hips right. If you are putting it under a large eve on an old ranch or something, then that isn't an issue.
    Good luck.
      EricPaulson | Sep 01, 2004 02:26am | #2
      There's a thread floating around here just now on this very topic. I will try to find it for you.
      EricEvery once in a while, something goes right!
    EricPaulson | Sep 01, 2004 02:27am | #3
    here, this might be of interest to you...........
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=46986.1
    Eric
Paying Homage to a Quintessential Cottage
A heritage property in the Adirondacks maximizes indoor-outdoor living space.
  • Track Lighting for Functional Ambiance in Busy Spaces
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
