pier-foundation technique
m_t_white | Posted in Construction Techniques on April 6, 2005 06:47am
I have a large deck project ahead of me…25 piers in all.  I will be using 24″ bigfoots for footers and sono tubes for pier forms.  I plan on wrapping the tubes with a few layers of 6 mil PE to reduce frost adhesion.  What I am wondering is, should I also backfill the piers with gravel?  I live in Vermont (cold winters) and the soils are wetter than normal.  I plan on the piers being 5′ deep.
Any opinions about the necessity of gravel or suggestions/advice about putting in piers would be appreciated.<!—-> <!—->
Thanks.
  1. rez | Apr 06, 2005 09:42pm | #1
    Greetings green,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
  2. mike4244 | Apr 06, 2005 10:34pm | #2
    I think, not positive that because you are using a bigfoot  footing form that frost heaving would not be a problem. I haven't used the bigfoot ,looks like a good product.You could leave the waxed sonotube on if they don't show. If you are going to strip the sonotube, make sure when you place them, the writing is up. Then when you strip them they will peel downward. Many years ago I told another carpenter that he was installing sonotubes upside down. He got real snotty with me, what he did not know that I was going to be his foreman in a couple of days. These sonotubes were 14'-0" high, surrounded by deck scaffolding, guess who stripped them. I laughed at him trying to peel the sonotube from the bottom. He quit at lunch time.
    mike
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
