Plaster/drywall: Ceiling to wall cove
WB | Posted in Construction Techniques on September 29, 2005 07:21am
I have a home built in the ’60’s. I think the walls are sheetrock(?) (what looks like cement on paper backing with thin coat of plaster over surface). The Living room and Dining room have
large wall to ceiling cove made of plaster, I’m guessing. The upstairs office has this same treatment, but only on one wall. The opposite wall/ceiling intersection is at a right angle. I would like to match the cove. I have seen styrofoam cove forms advertised that are then skim coated with joint compound I imagine, but I was concerned about telltale hairline cracks where the cove ends are feathered into the wall and ceiling. I’ve also seen the cove form built up with scrap wood covered in a metal screen, then shaped with progressive coats of compound using a piece of sheet metal cut to match existing cove’s radius. Any suggestions? Will joint compound work or would I be better off using a plaster mix or adding plaster of paris to the joint compound (I had a plasterer do this in a previous house for a quick drying, durable patch job) Thanks! WB
  1. YesMaam27577 | Sep 29, 2005 09:18pm | #1
    If yours was done in the 60's, then it was not done the way I learned to do it. (I'm  self-taught on this skill, learned by re-doing my 1917 house).
    I've successfully used the built-up wood, with mulitple coats of plaster. To avoid the cracking problems that you mention, I dug out a couple of inches of the wall plaster, and included that area in my new work.
    For one of those jobs, I had not learned about expanded metal (wire) lathe. So I used hair-reinforced plaster just like that used in 1917. Except I didn't have any horsehair, I used barbershop floor sweepings. It was about 20 years ago that I did that one. Saw it about 3 years ago and it still looked fine.
    For the others, I used wire lathe on the built up wod frame. Then multiple coats of plaster.
    Unless you're the lead dog, the view just never changes.
Outdoor Lighting
