Plumbing Goof Rosette cap
BillHartmann | Posted in General Discussion on August 19, 2006 08:05am
Customer has an old bathroom with tub and tile surround.
It appears that at one time or another the wall was opened and the maybe the vavles where replaced or not. But it appears that the tub spout location was changed.
Hard to tell what happened as the valves are old and could be orginal.
But there is a hole that was filled with thinset. It is into 2 tiles. Due to the color of the tile and the design I don’t see of any good way to replace the 2 tiles or even row and make it look like it was a design done on purpose.
Thinking of replacing it with color grout and/or staining it to get it near the color of the tile.
But I am wonder if there are any decorative chrome rosettes that you put used to cover this area. I am guess something about 1 1/2 – 2″ dia with a hidden fasterner (or glue on).
  1. joeh | Aug 19, 2006 11:39pm | #1
    Bill, how bout a Chiquita Banana sticker?
    Joe H
    james | Aug 19, 2006 11:50pm | #2
    soap dish or shampoo rack?
    I have seen blanks, most good plumbing supply houses should have a few to choose from.
    james
    IMERC | Aug 19, 2006 11:56pm | #3
    plumbing supply has what yur looking for...
    they are the clean out trap covers and come in a varity of styles and colors (brushed, chrome, brass paintable metal or plastic)
    there are snap in valve covers too in the same..
    WOW!!! What a Ride!
      BillHartmann | Aug 20, 2006 01:11am | #4
      The cleanout covers are too big.And the location is not right for a soap dish.But I found them after finding the right term to seach for.I have to spell it out for the censor.c.o.c.k. hole cover.http://www.a-ball.com/adtemplate.asp?invky=13768You will find a lot of VERY INTERESTING sites. Many of them don't have anything to do with plumbing.But Faucett hole cover will also work for a search term and you get better results.The snap in won't work.But many of them have a stud and use a backing plate and wing nut.I will either use a sealant to mount it and/or put a toggle on on the stud.
        IMERC | Aug 20, 2006 01:16am | #5
        I've seen the clean out covers as small as 1,75" IIRC..
        still too big???
          BillHartmann | Aug 20, 2006 01:33am | #7
          I just found some 1 1/2". But they all have a screw in the front of them. There all also friction fit ones, but they are only for bigger ones.Well it gives me some options, but I think that I will start with the hole covers first.
            IMERC | Aug 20, 2006 01:40am | #9
            a nice oval head SS screw and it should look just fine.....
      2. CAGIV | Aug 20, 2006 01:23am | #6
        better clear out your history, if your wife see's you've been looking for co ck hole covers it might be an uncomfortable few minutes until you get it straightened out
          BillHartmann | Aug 20, 2006 01:35am | #8
          No wife, no problem.But probably a good warning for others that might see this thread and want to know how they are used for non-plumbing purposes.
      3. rasconc | Aug 20, 2006 04:59am | #10
        Drill the patch, put in a plastic anchor and screw that stud in.
        Bob
      4. Shacko | Aug 20, 2006 06:00pm | #13
        If any censor on a construction forum does not know that the proper term is cock-hole cover then there is something wrong!. How about gage-cock, gas cock,etc. Plumbers have more sexual comments that they use. Luck.
        Edited 8/20/2006 11:02 am ET by Shacko
          BillHartmann | Aug 20, 2006 07:26pm | #14
          They might have toned down the list, but a supprising number of common words where being replaced with #####.
          1. Shacko | Aug 21, 2006 01:38pm | #15
            I think that it is counter productive, a person that is not familiar with the item will have a hard time finding it when the word has been censored. You can't ask for a ##### at the supply house!
  4. alwaysoverbudget | Aug 20, 2006 05:37am | #11
    any chance you could put a hand held shower where the hole is?larry
      BillHartmann | Aug 20, 2006 04:07pm | #12
      Interesting idea. But at the present time I don't have any access to the back side. It is back to back with a shower in the MBR bath. Some time in the future that is going to be demoed. But no access at this time.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
