“Plumbing ?” high temp plastic tubing.
BillHartmann | Posted in General Discussion on May 23, 2007 01:13am
I have an instant hot water dispenser that has started to leak.
For those that aren’t familar with these they are an “open” system.
The water goes to a valve and then to the tank. And from the tank to the spout on the valve.
The connection from the tank to the spout is plastic tube that has split.
There is no water pressure on the tubbing. But when dispensing 190 water flows through it and sometimes it releases a little steam.
In the spout it appears to be ordinary vinyl tubing from the hardware store.
Down where it connects to the tank it is white and right at the tank brown and hard.
I am wonder if anyone has any ideas for replacement that might withstand the tempature.
    jhausch | May 23, 2007 01:36am | #1
    Brakehose :-P
  2. splintergroupie | May 23, 2007 02:19am | #2
    Silicone tubing:
    Silicone tubing has long been used for medical tubing, as it meets the medical industry’s requirements for cleanliness and non-toxicity. Another of silicone’s major features — resistance to extreme temperature variations — has enabled its use in applications where a flexible tubing is needed to handle temperatures not possible with other plastics or rubbers.
    http://www.newageindustries.com/silicone_tubing.asp
      BillHartmann | May 23, 2007 03:44am | #4
      The silicon (and teflon) look like they might work.But they did not have the right sizes 3/8x1/2).But US Plastics does and sells some of it by the foot.
        jhausch | May 23, 2007 04:37am | #6
        Try smallparts:
        http://www.smallparts.com/products/descriptions/2100%2Ecfm
  3. splintergroupie | May 23, 2007 02:22am | #3
    here's a site with prices for 1/4", $1.20 a foot:
    http://www.store.cleanair.com/Tubing/1126.php
  4. WayneL5 | May 23, 2007 04:07am | #5
    Teflon tubing should.  Or metal.
  5. Boats234 | May 23, 2007 01:35pm | #7
    Bill,
    The 3 instahots I got are all ICE -In Sink Erator. I thought the vinyl tubing was just a vent and not a supply.
    My dispenser has 3 copper lines coming out of it and 1 vinyl tubing.
    Line #1- water supply
    Line#2- Supply to tank
    Line3#- Supply from tank to dispenser. -- Hot Hydrogen Dioxide out to make your peppermint tea.
    Vinyl tubing- Vent (P&T valve?) I thought.
    2 of my instahots only lasted 3-4 years then started leaking at the tank. Caused some water damage under sink before I found out about it. No pressure in the tank so leak was minute and probably vapor most of the time. Also my potatoes under the sink looked like they were trying to mash themselves.
    A tell tail sign of your tank leaking would be a delay in water supply out the dispenser. Since the tank is not pressurized, any leaking water would have to be replaced before it could be dispensed.
    If your sure your leak is coming from your vinyl tubing, I would just replace with whatever fits and not worry about any temp. concerns.
    1. BigBill | May 23, 2007 03:31pm | #8
      Sounds explosive.  Dihydrogen oxide would work better.
      1. Boats234 | May 23, 2007 03:42pm | #9
        Yeah, thats the ticket.
      BillHartmann | May 23, 2007 04:11pm | #10
      This unit replaced several ISE's over the years. ISE used copper tanks and they could corrode and leak in about 6 years.This one is a Quick and Hot http://quickandhot.com/They use a SS tank and it shows no sign of leaking.And it is definity only 3 connections. The plastic tubing is the vent and dispenser. And I can see how a separate vent line would work.About a year ago I installed an ISE for a client. They now use SS tanks..
Episode 1: Drywall Tools for the First Coat
Learn about mechanical and automatic tools such as the taper, the compound tube, and the banjo to make your drywall job better and easier.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
