In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
plumbing problem
| Posted in General Discussion on October 19, 2002 03:49am
Hello all-
I have a bathroom in which the toilet’s tank won’t refill unless the faucet is turned on. After you have flushed the toilet, the tank will not refill itself, regardless of how long you let it sit, until you have operated the faucet. Other than that quirk, both the faucet and the toilet work just fine. This faucet is the last one on a line that includes respectively a washmachine, guest sink, guest toilet, guest shower, master toilet, master bath and finally the faucet. The house is slab construction so the line is buried in concrete. I figure that it is some kind of vacumm but where it is, how it happened and if there are any solutions is my question to you. Any Ideas?
  1. geob21 | Oct 19, 2002 04:48am | #1
    I'd suspect it's in the toilet tank float valve. Something with the pressure shock in opening the faucet.
    Disconnect the supply tube to the toilet and if you have free flowing water switch out the valve.
    1. maneyj | Oct 19, 2002 05:01am | #2
      Had the same problem. I finally replaced the float valve and it works great.
Designer Kitchen Cabinets on a Budget
This Danish manufacturer has found a way to bring modern, architect-designed cabinetry to the masses.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
