In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Plumbing question
objector1 | Posted in Construction Techniques on February 19, 2008 11:01am
I am not a plumber but in the course of things I am forced into it on occasion. I am replacing a toilet due to breakage and water damage of the surrounding floor. The sewer lines are plumbed in cast iron with what appears to be a lead flange coming out of the cast iron that the toilet seated on. The toilet was attached to the floor with bolts into the subfloor and not into the flange because there were no mounting holes. The subfloor is rotted out in this area and I plan to repair with plywood. Currently the lead flange is 5/8 to 3/4 higher than the existing tile that is around the toilet. The plan is to replace a few tiles in this area after the subfloor repair.
The lead flange has a inside dimmension of 3 1/2 inches and has been flared out to about 5 1/2 outside dimmension. Can I just get a pvc toilet flange and slide it down into the existing flange and attach it to the subfloor with long screws into the new subfloor? How high does the new flange need to be above the surrounding floor tile? If I do it this way do I need to lower the heigth of the existing lead flange? Thanks.
  1. MSA1 | Feb 20, 2008 02:31am | #1
    We run into this occasionally. The flange should be on top of the tile or at least level with it.
    As far as cutting back the cast, you can actually do this with a pair of pliers. Just snap it off going all around the pipe. It works, doesnt seem like it would but it does.
    Never seen a pipe flared out to 5 1/2". Hopefully you can find a plastic replacement.
    You could go with another cast flange but then you need to be able to melt lead to put it back together.
  2. jayzog | Feb 20, 2008 03:37am | #2
    I would take a pair of pliers and bend the lead straight inline with the pipe, this should be easy, remove the flange, repair the subfloor, screw the flange back down,than beat the lead down over it with a hammer. That is how it probably was installed in the first place and should work again. The wax ring then will seal to the lead where you have flared it out over the flange.
    If the lead is in bad shape and wont take the bending and reforming, I would then demo back to a point where you can attach to the cast with a mission coupling and adapt to plastic.
    A pvc flange will have an OD of around 3 5/8", in you can get it into your lead pipe it won't really seal, perhaps allowing gasses to escape.
    There is also expansion flanges that go inside the pipe, but I have only seen them for 4"  waste, I think they would be to much of a restriction on 3.
  3. BungalowJeff | Feb 20, 2008 04:40pm | #3
    I had to do this in one of my bathrooms. I took the lead out since it was damaged with the subfloor. A hammer and old chisel will get it out. Usually the lead is set in the hub of the last section of CI, which is usually an elbow. I bedded a piece of no-hub-CI into the existing hub with epoxy.
    Fernco donuts are available to insert for the hubs too, but no one carries them in my area. I guess you can also use a section of PVC, but I had a length of 4" CI leftover from the upstairs bathroom total gut job.
    ...that's not a mistake, it's rustic
  4. BryanSayer | Feb 20, 2008 05:43pm | #4
    I would add one caution: If the cast iron pipe goes back to the vertical stack as one piece you should be fine. However, if the horizontal line joins the vertical stack with a lead joint, you should consider replacing back to and including this joint. The reason being that this is a failure prone joint. I do not recall the details of how it is done, but I know my plumber was able to do it in about 1 or 2 hours, so it is horribly difficult (provided you have access). I imagine there is a specialty coupling to do it.
  5. objector1 | Feb 20, 2008 11:47pm | #5
    Thanks to all for the advice! With your kind words I was able to successfully complete the repair today.
Forming Foundation Walls
In the first episode of FHB House Kansas, Travis and Joe of Catalyst Construction walk through details of their foundation walls.
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
  • Fastener System for Solving Deck Fascia Board Expansion
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
