Plumbing – Side wall vent screen?
MikeMicalizzi | Posted in General Discussion on February 13, 2007 04:28am
Planning a retro fit bathroom project in an existing basement that will involve running a sidewall vent to properly vent the fixtures (shower/sink/toilet). The terminated vent (or vents, might run two) will simply be a 2″ pvc pipe (coming out of the outside wall) connected to a (2″) 90 degree pvc fitting. The IRC states that side wall vents require a screen or other bird and rodent protection. I’ve never seen any such product that attaches nicely to pvc that has any type of screening built in like that.
Has anyone seen any type of screen product specifically made for sidewall vents that attach to pvc?
Thanks in advance, Mike
  1. plumbbill | Feb 13, 2007 04:52pm | #1
    I can't believe that side wall vents are legal, but that's why I don't deal with the IRC, & only deal with the UPC.
    But anyway, you can cut a slightly larger circle of mesh than the OD of the pipe, force into cup fitting.
    Then cut a very short piece of pipe & glue into cup.
    "The nearest thing to eternal life we will ever see on this earth is a government program." - Ronald Reagan
      MikeMicalizzi | Feb 13, 2007 05:06pm | #2
      Thanks for the tip Bill.
      If I don't run the vent through the wall, then there's two choices, either AAV's (air admittance valves) or attaching to the main stack, I believe that method is called "reventing". I just figured going out the sidewall was easiest since it's fairly close.
      1. Shacko | Feb 13, 2007 07:15pm | #4
        I would not use a AAV unless I had no other options, [they are not true vents]. The best hook-up is to tie a secondary vent into the main stack vent or vent stack, your call. If you decide to use the side-wall vent one way is to buy a piece of metal screening, wrap it around the discharge of the vent and secure with a large hose clamp. Where I work they don't allow them, so I'm sure someone has a better idea. Lots of luck......................................
        "If all else fails, read the directions"
          MikeMicalizzi | Feb 13, 2007 10:05pm | #5
          Thanks for the feedback guys.
          There are no windows down there since it's a "mostly" underground basement.
          It's hard to believe that nobody makes something specific for this. Now-a-days there seems to be a product/tool for almost anything you want to do.
  2. davidmeiland | Feb 13, 2007 06:54pm | #3
    Any windows in that side wall?
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
