Do you consider 1/2″ 4-ply CDX superior to 7/16″ OSB for exterior sheathing?
Or is 4-ply some kind of off-spec stuff?
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
This discussion has been done many times here (over 500 messages). You will still get different opinions from different people.
As for me personally, I have framed 2 houses in the last 3 months, both around 4000 sq. ft. plus garages. I framed one with Advantech subfloor, 7/16 OSB for walls, and 5/8 OSB for roof. AdvanTech is the best subfloor I've ever used. 7/16" OSB is showing some signs of slipping QC with odd sized panels, slight out of square, and improperly placed nail lines or missing lines. 5/8 OSB has been standard for roof sheathing in my company for about 6 yrs now with no failures or quality issues. I switched slowly from plywood to OSB when I started having problems with delaminations, multiple core voids, curved lines, and so on. I changed wall sheathing first, then floor, and finally roof after I had to remove a bunch of 5/8 CDX from a roof at my expense.
The second house I framed entirely with plywood at clients request. He is from Conn. and claimed that OSB was hardly ever used there and sees it as a cheap product for cheap construction. He's 72 yrs old and not easily swayed from his opinions. Well all the same problems are there save the roof so far ( it's not delaminating ). The 1/2" CDX is terrible and nearly imposible to install to look as though it was by a professional. The 3/4 T&G floor sheathing is swolen and delaminating at the edges. So it's safe to say that I'm in the OSB camp for now.
k
county will not let osb use on roofs around here.
