I need to hang a set of heavy pocket doors, and I dont want to use the usual cheap hardware. Does anyone know of a source for hardware meant for heavier doors?
A standardized approach, quick-to-install hardware, and a simplified design make building custom casework cost-effective.
If you look to the left top there a "Advanced Search" feature. The words "Pocket Door Hardware" got 68 responses.
I prefer the pocket hardware from "Accuride" that uses the wire cable system and the "Blum" thick doors hinges (get the clip-on type hinges). Forget the types that used the follower strips. If you need REALLY heavy stuff, contact "Haffele" and they have a type that will retract full size doors as in interior doors or partitions.
