In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Poking holes in gravel ?
geoffhazel | Posted in General Discussion on July 3, 2006 09:31am
I need to plant some sticks for support in a gravel area, 5/8 minus hard packed. The sticks are 3/8″ wood and need to go down about 4-5 inches for best support.  I have to do a lot of them, and don’t relish trying to dig into the gravel with a shovel.  I tried a 3/8″ masonry bit in the cordless drill, with some success.  The problem I have is that when the drill is extracted, sand and material fall back down the hole and fill it up.
Is there a better way to do what I’m trying to do?
  1. PatchogPhil | Jul 03, 2006 09:32pm | #1
    Drive in some rebar pieces cut to an angle point,  with a sledge hammer.
    1. geoffhazel | Jul 03, 2006 09:38pm | #2
      That would work if I needed a rebar support...but what I'm trying to do is plant little flags in front of people's houses in the neighborhood as a promotion for my business.  And the flags are on 3/8 wooden sticks.
      I mean, sure I could plant the rebar and then tie wrap the flags to it, but that's a bit overkill for this project.  I have 900 flags to plant in the next 20 hrs.
      not ALL of them go into gravel, but enough that it's worth finding a good solution.
      1. PatchogPhil | Jul 03, 2006 09:42pm | #3
        Get an auger bit meant for drilling holes for flower bulbs - they pull up the soil with it.  Mayeb they are 1 1/2 to 2" hole.  Then push the extra soil back in around the little sticks.
      2. Piffin | Jul 04, 2006 01:36am | #8
        better think twice about planting flags on somebody elses property without permission. you are likely to piss off potential customers and even face tresspassing or littering charges. it has happened.
          JeffBuck | Jul 05, 2006 02:06am | #9
          where did he say it's without their permission?
          Jeff    Buck Construction
           Artistry In Carpentry
               Pittsburgh Pa
          1. Piffin | Jul 05, 2006 02:26am | #10
            he doesn't, but can you see him knocking on 900 doors in 20 hours and getting permission to plant little banners to advertise and promote his business?
            JeffBuck | Jul 05, 2006 02:36am | #11
            U do have a point there ...
                 Pittsburgh Pa
          3. Piffin | Jul 05, 2006 03:12am | #13
            now you've gone and made me re-read and re-think the whole scenario. maybe these houses line a street where there was to be a parade and the flags are the red,white, and blue, and he was acting on a volunteer basis, with just one notice made that his company was doing the public service...
            Matt | Jul 05, 2006 04:15am | #14
            Around here public roads typically have a right of way that might be 45' wide and the actual pavement is maybe 30' wide meaning that each property owner's parcel front corner stakes are actually set 7.5' back from the pavement.  Although people get pretty comfortable with thinking they own right up to the pavement, actually they don't.
            Private roads are undoubtedly different.
            If I wanted to plant these little flags, I'd maybe use something like a large Phillips screwdriver driven in the ground (gravel) with a hammer, pull the screwdriver out, and push the flag in.
          5. DavidxDoud | Jul 05, 2006 04:33am | #15
            ya,  and iffen you use a 'Craftsman' screwdriver,  ya kin git a new one when yur dun...75576.1
            <g,d,&r>
             "there's enough for everyone"
          6. DaveRicheson | Jul 05, 2006 02:28pm | #18
            Right of way does not mean lack of ownership. Right of way does mean that the specific user has a right to enter and maintain something on your property, be it utilities, drainage or whatever is described in the right of way easement on the plot or Platt plans.
            A public right of way does not necessarily mean that anyone can use your property for any form of private advertisement, only that they may cross through your property without you explicit permission.
            If a property owners line is set back an easement, unless required by jurisdictional ordnances, they need not maintain public property.
            I went through a interesting trail by fire when they installed sewers in my last neighborhood. My corner stake where at the edge of the road, but the easement extended 18' into my property. The contractor thought he could leave me with less than acceptable work when restoring my property to its former condition because he was in the "right  of way." He found out differently, and I learned a lot about right of ways and easements.
            Dave
          7. User avater
            Matt | Jul 06, 2006 04:34am | #27
            I'm not gonna spend a lot of time typing...:
            The above is entirely different and unrelated to an easement.  As you said - your property corners were right out at the pavement.  Indeed, in the above example, the property owner does not own the 7.5' wide strip of property between his property and the paved street.  It is owned by the state, county, or whoever owns the road.
            Edited 7/5/2006 9:39 pm ET by Matt
          8. User avater
            JeffBuck | Jul 05, 2006 05:12am | #17
            I went back and had second thots too!
            Now I'm wondering just what the hell is going on?
            datails dammit ... we demand details!
            and pictures ...
                 Pittsburgh Pa
        2. JohnSprung | Jul 05, 2006 11:00pm | #24
          Out here, the real estate agents do this for Memorial Day and 4th of July.  American flags about 9" x 12", with their business card attached to the stick.
          -- J.S.
          1. BryanSayer | Jul 06, 2006 12:28am | #26
            Where my parents are they do it for Memorial Day also.It's called "Flags In"http://www.arlingtoncemetery.net/memorial-day-flags-in-2004.htm
    IMERC | Jul 03, 2006 09:44pm | #4
    larger dia hole drilled deeper to compensate for the material that will fall back in...
    work thru a tin can with both ends cut out.. use the can as a retainer wall system to keep the material from falling back in...
    sub it out.....
    WOW!!! What a Ride!
      intrepidcat | Jul 03, 2006 11:55pm | #5
      basically a cofferdam..........
      I agree...............sub it out.
      If having a low wage work force was good for a country's economy then why hasn't Mexico built a fence?
        IMERC | Jul 04, 2006 12:06am | #6
        Oreo offered....
        But what he do with 900 holes he'd need heavy equipment to fill back up...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
        1. Shep | Jul 05, 2006 02:57am | #12
          How's Oreo doing?
          What's the word from the doctors?
            IMERC | Jul 05, 2006 04:43am | #16
            Oreo is with me... won't get the skinny till I get back to Colorado...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
          intrepidcat | Jul 06, 2006 06:34pm | #30
          LOL
        IMERC | Jul 04, 2006 12:07am | #7
        ship auger and the coffer dam...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
  3. maverick | Jul 05, 2006 02:47pm | #19
    I once got the same task on a union job. had to set a lot of pins into gravel.
     simple solution, chuck the pins and drill with a hammer drill. they go right in
  4. LeeLamb | Jul 05, 2006 05:20pm | #20
    Be sure to contact your state's One-Call association before you commence work. Interupting utilities can be dangerous and costly.  The calls and locates are usually free and can save you a lot of hassles.  Good luck.
    jhausch | Jul 05, 2006 05:34pm | #21
    Here's a thought - If the sign is not alreday attached to the wooden dowel, you could beat in a length of iron pipe, then put the dowel in the pipe and extract the "tool".
    (see attachment)
    I don't know if this will work.  The center of the pipe may just fill up with the gravel, too.  Easy enough to test. . .
    Good luck.
    http://jhausch.blogspot.com
    Adventures in Home Building
    An online journal covering the preparation and construction of our new home.
    Edited 7/5/2006 10:35 am by jhausch
    1. BillBrennen | Jul 05, 2006 07:38pm | #22
      Jhausch,I had the same idea, but the OP said that the flags are already mounted to the wooden sticks.I suppose one could cut a whole bunch of 1/2" black pipe and leave a sleeve in every gravel location...homeowners might object to that.Bill
      1. geoffhazel | Jul 05, 2006 09:50pm | #23
        Here's what I wound up doing:
        1. Look for a soft spot (lawn, bed, etc.) near the front of the house.
        if no such spot is available (due to shrubbery or rockery) and you HAVE to go into the gravel, I used a large slotted screwdriver w/rubber mallet.  Brush away some of the gravel at the surface, drive screwdriver in, wiggle now and then, brush away loosened gravel around the shaft, drive in a bit more.  Now I have brushed away about 3" of gravel, and have the tip of the screwdriver down another 2" or so.  Position the bottom of the flag right next to the driver, and insert quickly into the hole as the screwdriver is removed in one motion, to minimize material falling in.  Give the flag a couple of gentle taps with the rubber mallet to seat it, then brush the loose material back into the crater around the flag.  It won't pull out or fall over, and that's the goal.  Takes a bit longer than just driving it into dirt, but pretty effective.
        You guys helped me quite a bit with ideas. I was having good luck with the carbide drill once I switched to a LARGER bit than I needed, but all in all, the big screwdriver was quite effective.  Took about 45 seconds or so to plant a flag.  Allowing some flexibility in the location also cut down by 75% the need to even go into the gravel.
        And so far, my response on the flags has been 100% positive.  In cases where people were outside as I came by, I'd ask permission and got a YES in every case, and often people would even thank me for their flags.   I had one or two people who were just getting into their cars to go somewhere drive by, open the window and say "Thank you for the flag" as they passed.
        The "promotional material" is just my name and # on an address label wrapped around the stick.  Most people probably won't see it until they go to unplant the flag, it's the same color as the stick.  Kind of "low key" so as not to distract from the general goal of decorating the neighborhood.
        Edited 7/5/2006 2:55 pm ET by geoffhazel
      2. Piffin | Jul 05, 2006 11:38pm | #25
        I sure would! The frost would heave it out and the mower blades would not like it.
          JeffBuck | Jul 06, 2006 07:17am | #28
          U were right.
          I'da never thot to step onto someone's property without permission let alone stake a flag in with my biz name attached.
          must be Mayberry ... I'm thinking that's a good way to get yer butt kicked around here! Or arrested and sued in the better neighborhoods I work in ...
          funny ... the thot of a "no permission" deal just never crossed my mind ...
          just strikes me as wrong.
               Pittsburgh Pa
          1. PGproject | Jul 06, 2006 08:05am | #29
            Here in San Francisco, an American Flag on your property is, sadly, an invitation for vandalism.Bill
Getting Shed Dormer Elevation Right
Drawing a full-scale picture on a scrap of plywood can help get the ridge looking straight.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
